YB11 Coolant Change
Rich
PostPosted: Mon Sep 27, 2010 10:51 am    Post subject: YB11 Coolant Change Reply with quote
Hi All, I would like to change the coolant in my YB11, but can't see any drain points. Has anyone had a go at this job themselves and can give me a few pointers and if there are any traps for young players that I should be aware off?
Thanks Rich Smile
PostPosted: Mon Sep 27, 2010 9:54 pm    Post subject: Reply with quote
i'm sure there's a drain in the water pump housing on the LHS of the engine. 8mm headed bolt. . ..
PostPosted: Wed Sep 29, 2010 9:02 am    Post subject: Reply with quote
Rich
I did mine at the weekend, Best place to split the system is the big hose on the nearside at the bottom by the rear sprocket and remove the rad cap. There are two small drains on each side of the cylinder block - small 8mm bolts. When I took these out the water was like brown soup!! I then used a hosepipe to backflush the system through every hole until it ran clean. I cant remember if there is a drain on the pump but I didnt need it. I then reconnected and filled up, ran the engine and kept topping up until no more bubbles appeared at the cap. I then had a 10 minute run on the bike and repeated the above but used antifreeze mix to refill - this gets all the muck out! Very Happy
Rich
PostPosted: Wed Sep 29, 2010 10:07 am    Post subject: Reply with quote
Awesome.Thanks for the info, sounds easy and I have spotted the drains you mentioned. Will have a bash at it this weekend. Rich. Very Happy
PostPosted: Thu Oct 21, 2010 11:51 am    Post subject: Reply with quote
Rich did you get the coolant changed ok? Very Happy
Rich
PostPosted: Thu Oct 21, 2010 1:03 pm    Post subject: Reply with quote
Hi, Coolant changed Ok but have discovered that my radiator cap has seen better days. I am having a lot of trouble finding a replacement for what looks like a fairly standard item Question The closest I have found is off a KTM, but it is rated at 1.4 whereas the original is 1.2. Not sure if this will be a problem or not?? Bike is still sitting under the house with fairings off. Crying or Very sad Anyone have any suggestions?
PostPosted: Wed Oct 27, 2010 11:09 am    Post subject: Reply with quote
Rich
I'll have a look at mine to see what it says. Does a new standard Yamaha one fit? Nige
Ynot
PostPosted: Thu Feb 28, 2013 1:27 am    Post subject: Reply with quote
Hi Rich,
I bought a yamaha thunderace radiator cap thinking Bimota had to have fitted a Yamaha cap. But now I find the new cap is not the right item. Did you or anyone else ever identify what the correct radiator cap was? Thanks.
Rich
PostPosted: Thu Feb 28, 2013 7:44 am    Post subject: Reply with quote
Hi Ynot, No I was unable to find a replacement cap. I just carefully cleaned the rust off mine and painted it and it seems to be holding OK.
Cheers Rich.
PostPosted: Fri Mar 01, 2013 12:01 am    Post subject: YB11 Coolant change Reply with quote
If it's a neck on a hose like the SB6R you won't be finding a replacement. You need to get somebody to make you a new neck up that will take a readily available cap.
