BimotaBoy
Posted: Fri May 21, 2021 2:14 pm Post subject: Damper rubbers |
I need some replacement shock absorber dampers - if that's what they are called - for a Tesi 1D. Anyone know where I can get some |
Posted: Sat May 22, 2021 9:27 am Post subject: |
They ate called "bump stops"....search off road shock absorber bump stops...suspension refurb companies sell the also...fitting is the issue....but...you can slice it open...and push through onto rod and superglue the slice...otherwise you have to take the bottom locating eye off the damper rod.. |
