Weed
Posted: Tue Oct 05, 2021 1:34 am Post subject: |
Trev, next instalment is the swing arm |
Weed
Posted: Sun Oct 10, 2021 1:17 am Post subject: |
The changing of the swing arm.
Towards the end of the build I got in contact with Piero & asked him if he had any race shop parts left over.
He said that he had a un machined SB8R swing arm that was from the Gobert era WSBK if I wanted it.
Is the bear a catholic? Does the pope shit in the woods? Take my money mate.
A few weeks later the swing arm arrived with 2 sets of machine shop drawings. Each of the drawings were slightly different which in turn were slightly different to the swing arm in the bike. I forget what the differences were now.
I took the arm to Clyde but he’d didn’t want to do the machining knowing it was a 1 off & really didn’t have the machines to carry out the work. He sent me another company and they carried out the majority of the work. Even though it took a fair while, it was not finished off very well (just small details) so I went back to Clyde & he cleaned up the areas that needed detailing.
I searched for a company in Aus that could coat the arm & found a business in Melbourne that makes Mag wheels for the V8 supercar series here & he had a big enough treatment tank to coat the arm.
At the same time I had been playing around with making an alternator cover in an alternative material & settled on a 3D printed cover in a carbon fibre matrix. Unfortunately the end result was porous & when that problem was solved, it was to flexible & flexed between the securing bolts & subsequently leaked. I asked the company in Melbourne if he was interested in making a couple of covers out of magnesium & said it was no problem. After about 3 months, the finished parts arrived back in Perth looking pretty good.
Trev offered me a set of Magnesium chain adjusters that he was the proud owner of so we had a bit of a trade which has resulted in the complete swing arm assembly being in Magnesium.
The un-machined cast part of the swing arm has darkened over time but it still looks good while the alternator cover has maintained its’ factory finish
Posted: Sun Oct 10, 2021 10:06 am Post subject: |
Gorgeous...... |
Posted: Sun Oct 10, 2021 9:28 pm Post subject: |
Now that is unobtanium! Is the swingarm solid magnesium, or hollow? It looks solid where the cut-out for the shock linkage is. |
Weed
Posted: Mon Oct 11, 2021 3:29 am Post subject: |
stockcar wrote: |
Gorgeous...... |
Yes mate. The casting is a beautiful piece but the Italians are well known for high quality castings. |
Weed
Posted: Mon Oct 11, 2021 3:33 am Post subject: |
Bud977 wrote: |
The casting is mainly hollow Bud, you can see vent ports around the lower edge of the casting at the front but it is solid around the linkage connection point. I don't know how they do that magical stuff |
Posted: Mon Oct 11, 2021 9:30 am Post subject: |
There are some nice bits on the beast thats for sure |
Posted: Mon Oct 11, 2021 9:16 pm Post subject: |
Weed wrote: |
Bud977 wrote: |
Yep, don't know how you'd do a hollow casting. Definitely magic. |
Posted: Mon Oct 11, 2021 9:45 pm Post subject: |
Its not to late to get a VDUE Lech , turn up at the race meeting with that heads would spin |
Weed
Posted: Tue Oct 12, 2021 2:10 am Post subject: |
trev45 wrote: |
What's a Lech mate? |
Posted: Tue Oct 12, 2021 9:27 pm Post subject: |
Weed wrote: |
trev45 wrote: |
Not what, who. That's me, mate. |
Posted: Tue Oct 12, 2021 9:33 pm Post subject: |
trev45 wrote: |
For sure Trev. Can't have too many two strokes. Add it to the 4DP TZ250, TZ250A, TZ250U, TZ350E, Simpson TZ350, NS400R, RD350LCs, RS125 plus the dirt bikes. |
Weed
Posted: Wed Oct 13, 2021 12:24 am Post subject: |
Bud977 wrote: |
Weed wrote: |
trev45 wrote: |
Now I understand Trev's reply. A great collection there Bud
Cheers |
Weed
Posted: Sat Oct 23, 2021 3:06 am Post subject: |
Getting close to the end now so her are the carbon air tubes
The original air tubes are very restricted so the mission was to form a new set of air tubes. I have always liked the carbon tubes that came with the carb conversion models. Clyde to the rescue. He used the original tubes as a basis so as to enlarge the carbon ones. He built up the outside of the original tube with a removable putty like substance & formed the tube to fit to the original airbox & remove all the internal restrictions. He then gave these to the Brett the carbon fibre man to make moulds from.
They made a cheap & nasty set out of fibre glass to check on the final fit & when that turned out fine, the final carbon set was made, and a lovely result it was.
I am currently getting the airbox made out of carbon but that is a few weeks away from being finished due to different hold ups in getting the moulds made so that's all for now |
Posted: Sat Oct 23, 2021 2:56 pm Post subject: |
Nice carbon work buddy |
