NewBimotaYB11
Posted: Sun Jan 16, 2022 7:10 am Post subject: YB11 Purchased with 2800km What to Service? |
Hi All,
Just purchase a YB11 and need to know what needs to be serviced. The bike has 2800km and has only been around the block and had its brakefluid changed.
What needs to be done to keep it fresh. I will not ride it but for the trip around a longer block than before?
Peter _________________ Thanks
P |
Andrew034
Posted: Mon Jan 24, 2022 9:26 am Post subject: |
With 2800km it's low mileage for the age.
Personally I'd change all fluids:
Oil and filter
Coolant
Fuel
Brake and clutch
If you're keen
Forks and rear shock too
Additionally I would normally change the spark plugs.
If the fuel is OK the filter can be left, but you may consider it too
I'd check the air filter, but it should be OK.
If the tyres are over 3 - 5 years change them to
Check the chain tension and also lube it.
Check the brakes, they should be OK but expect some rust and maybe they will need rebedding in.
Normally I'd also add some cleaner to the fuel to clear the carburettors, I've had poor running after a long sleep.
Also expect some leaks during initial riding, so check the bike carefully during initial usage - forks can be problematic as can fuel connectors.
Andrew... |
Posted: Tue Jan 25, 2022 1:00 am Post subject: |
If it's been sitting for a while, the carbs will need a strip and clean. Even if the float bowls were drained when it was parked up, the residual fuel in the carb internals turns to shit. A complete strip and ultrasonic clean is the best way. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
NewBimotaYB11
Posted: Sun Jan 30, 2022 1:44 am Post subject: |
Thank you!
P _________________ Thanks
P |
