Key blanks
RAB
PostPosted: Wed Aug 10, 2022 2:39 pm    Post subject: Key blanks Reply with quote
HI, I have a 1998 YB9SRI that I got with only one key which does not seem to have any code on it. After some research I think the correct code might be .ZD22RBP-SI. Can someone please tell me if that is the correct code or whether I am wrong? I also need to know if I can source a blank for the filler cap so if anyone knows where I can get one ...... ?
Too many bikes, too little time.
PostPosted: Mon Aug 15, 2022 7:22 am    Post subject: Reply with quote
I'm not sure where you live RAB as your profile is blank....Here in the UK I simply went to my local |Timpsons Key cutter and he sourced and had in stock the blanks for both ignition and petrol cap keys....ebay also lists "blanks"...
