DB1 Exhaust sytem needed
stratos23
PostPosted: Tue Apr 25, 2023 10:29 pm    Post subject: DB1 Exhaust sytem needed Reply with quote
Hello from New Zealand...
I'm in the process of recommissioning a recently-discovered DB1 that's barely turned a wheel since it left the factory.
The standard exhaust system is a real pain on these. Ideally you either cut the mufflers off the headers (because they're welded on) and put slip-joints on or replace the entire system. These exhausts are as new, so I'm loathed to cut them - would rather just put them on the shelf for now. I have Australian made Stay-In-Tune mufflers on my older DB1 and they're great!
SO, does anyone out there have either some headers and/or a exhaust system they might want to part with? OR a DB1RS style 2-into-1 system?
Many thanks, Greg
DB1 . Ducati F1 . Ducati TT2 . Ducati 450D . Guzzi LM1 . Morini Kanguro
