JunTakei
Posted: Sat Jun 10, 2023 10:28 am Post subject: How to remove Tesi-3D front cowl |
I'm Jun. I live in Japan.
First of all, this sentence is translated into English by google translation, so it may be a little strange.
Well, I got a tesi-3d LE last July.
The wiring is a mess, so I'm arranging it.
The question is how to remove the front cowl from the main body.
The front of the cowl is quite narrow, so it won't come off due to the lights and stays.
Anyone know how to remove it?
thank you. _________________ Takei Jun |
Posted: Fri Jun 23, 2023 10:57 am Post subject: |
Hello Jun, welcome to the forum. I know nothing about the Tesi so am no help to you sorry. If it is a one piece fairing like the 90's bikes, once all of the fasteners are removed, you have to pry open the fairing carefully to get it past the front wheel. I have no idea if the Tesi is the same. There are a few Tesi owners on here, so hopefully someone will be along shortly to help you.
Cheers _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
JunTakei
Posted: Tue Jun 27, 2023 7:58 am Post subject: |
Hello Brian. Thank you for your advice.
I have a workshop manual and it says "unscrew the fixing screw, open it slightly and slide it forward". However, the cowl is very narrow. Is it possible for a carbon cowl to spread so much?Please look at the photo.
Thank you.
Apollo2
Posted: Wed Jun 28, 2023 11:35 pm Post subject: |
Unplug the turn signals and remove them.
Remove the turn signal mounting brackets.
Remove both side-covers below the tank.
Remove the two screws circled in your photo.
Spread the fairing/cowl and remove it. |
Apollo2
Apollo2
Posted: Wed Jun 28, 2023 11:36 pm Post subject: Re: How to remove Tesi-3D front cowl |
JunTakei wrote: |
thank you. |
JunTakei
Posted: Thu Jun 29, 2023 9:00 am Post subject: |
Hello Apollo2
Thank you for the information.
After all, it seems to open the cowl and remove it.
I'll try it later and let you know how it goes.
Apollo2
Posted: Thu Jun 29, 2023 4:14 pm Post subject: Multiple Posts - Error |
Sorry for the multiple posts. Each time I hit [SUBMIT] I got an ERROR message, so I kept trying. Finally, in a last-ditch effort, I emailed Jun Takei. Today, everything showed up on the forum.
If there is an edit or delete function in this forum, I cannot find it. |
Apollo2
Posted: Thu Jun 29, 2023 4:15 pm Post subject: Multiple Posts - Error |
General Error
Failed sending email :: PHP ::
DEBUG MODE
Line : 234
File : emailer.php
If there is an edit or delete function in this forum, I cannot find it. [/i] |
JunTakei
Posted: Thu Jun 29, 2023 8:13 pm Post subject: |
Hello Apollo2,
I got your message. thank you.
According to the FAQ, it seems that you can edit and delete your own posts with the edit button.
Posted: Tue Jul 25, 2023 9:03 am Post subject: Re: Multiple Posts - Error |
Apollo2 wrote: |
General Error
DEBUG MODE
Line : 234
File : emailer.php
Yes indeed....you click the edit button on each post...and then you can delete the repeat posts |
JunTakei
Posted: Thu Jan 18, 2024 1:13 am Post subject: |
It's been a while since I posted, but I was able to safely remove the front fairing of the TESI-3D.
I opened the fairing and moved it forward and then downward to remove it. I now have access to the ECU and fuse box.
I'm considering replacing the ECU with open hardware and an open hardware Speeduino.
Thank you everybody.
