split type clear timing belt cover
JunTakei
PostPosted: Sat May 25, 2024 11:41 pm    Post subject: split type clear timing belt cover Reply with quote
Hello everyone.
I made a split type clear timing belt cover for TESI 3D.
I needed to inspect the timing belt and had trouble removing the original cover. Especially on the horizontal side,
the wire harness and aluminum spacer are in the way.
I was able to remove the cover by removing the aluminum spacer.
I made a split type clear cover so that I can easily inspect the timing belt next time.
I can easily remove the side covers after removing the top clear cover.
・Obtain a carbon belt cover for Ducati at auction. (I will save the original).
・Since only the sides of the cover will be used, cut off the top.
・The upper clear cover is made of polycarbonate.
・The stay that connects the carbon side and top is made from polycarbonate.
・Use screws to combine to complete a split clear cover.
This sentence was translated from Japanese to English using Google Translate.
Takei Jun
PostPosted: Mon May 27, 2024 10:31 am    Post subject: Reply with quote
Nice. Looks very neat
