BST wheel help all owners
PostPosted: Tue Nov 02, 2010 10:24 am    Post subject: BST wheel help all owners Reply with quote
Hi all. can you have a look at your front forks at the bottom, left hand fork as you sit on the bike and see if there is a small cutout at the top of the gold bit for the speedo triggers that are attached to the disc.
I suspect that all Milan bikes (post 2000) have electronic speedo but am not sure if the original Rimini bikes had electronic or mechanical (duc 916) speedo drives fitted.
Im just trying to find out as the BST wheel I have bought do not sit centrally inbetween the forks with the spacer provided. all replies appreciated Very Happy
CBar
PostPosted: Tue Nov 02, 2010 4:39 pm    Post subject: Reply with quote
I don't have a V Due, but the forks appear to be the same 46mm Paioli that is used on my SB6. I do know that the Ducati wheel with speedo drive will fit, but you will need to make a spacer for the right side.
Here is a picture that shows the electronic speedo mount.
http://p1.bikepics.com/pics/2008/05/20/bikepics-1295433-full.jpg
Let me know if your wheel doesn't work out and you want to sell it. Very Happy
PostPosted: Wed Nov 03, 2010 9:41 am    Post subject: Reply with quote
Thanks for the reply. I've managed to find a guy on the Vdue forum on multiply who has fitted BSTs to his - he made his own spacers!! I suspected that was the answer, better get the lathe cranked up Smile .
PostPosted: Fri Nov 12, 2010 11:13 am    Post subject: Reply with quote
Just a test to see if I can upload a picci from Photobucket!!!
[/img]
wahay!!
husson73
PostPosted: Tue Mar 29, 2011 10:07 am    Post subject: Reply with quote
All V due have electronic tacho speedo and two kind of it.
husson73
PostPosted: Thu Mar 31, 2011 5:17 pm    Post subject: Reply with quote
you can see them on Bimota enthusiasts V due gallery beware the one with the round tacho on the middle don't seem original.
The first typ is the same the one on the SB6R excepted the red line Cool
