Instrument panel KOSO DB5 - DB6
Zeus
PostPosted: Tue Feb 10, 2026 3:01 pm    Post subject: Instrument panel KOSO DB5 - DB6 Reply with quote
Good morning from Spain.
Can anyone tell me the model of the KOSO speedometer that was installed in the DB5 and DB6?
Not the round, white speedometer that the first DB5 Mille models had, but the one that was installed later.
Do you have the part number?
Or does anyone have the installation instructions or manual?
jamormar1@upo.es
Thanks
PostPosted: Fri Feb 20, 2026 11:28 am    Post subject: Reply with quote
Koso RX2N as below.....2 types under this name...one with higher RPm...you need the lower RPM one https://www.ebay.co.uk/itm/373662157667?_skw=koso+rx2n&epid=2222865726&itmmeta=01KHX9ES4ET26HCFN3HV1QKQPB&hash=item5700000b63:g:kNUAAOSwCYtnP20A&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xAyXec7nBTYLWATh5HyssVBqWdPQGHy9xWQ8Cfl1jQBI%2BZSg3thmjQ0OlSnqBIj6JFNBMql%2F5LBk7k1dghoKHGEi8RswiRPWDtdi%2BCysJQhCrYaLnE3qp1pu%2FMu7RaPawwFCfJuHmIS%2BxkyySv8SU2pdDAb8TYL54u7HVI1lp4No1WF4qxf88ZAbeMBsInXau7wkG9pEKH2xs2DqAeqaoSVocA41wOLus0fTSIrKzzVRWCnBsWb8vEv5HnwEJ6c6zk%3D%7Ctkp%3ABk9SR7SSu6mPZw
