Carb settings on an SB6R
gobert bimota
PostPosted: Thu Nov 04, 2010 3:05 pm    Post subject: Carb settings on an SB6R Reply with quote
Hello
Does anyone know the carb settings on an SB6R?
Thanks
PostPosted: Thu Nov 04, 2010 4:33 pm    Post subject: Reply with quote
To get my 6R running anywhere near I disconected the fuel pump, had the carbs ultrasonicly cleaned and then had it set up on a dyno Wink
The current carb settings are not even close to what Bimota say they should be.
When I set the carbs to Bimot's settings, the engine would only tickover with full choke. Crying or Very sad
Brad
PostPosted: Thu Nov 04, 2010 10:02 pm    Post subject: Carbs Reply with quote
I've been told that the pump needs to be serviced.It looks like the pump on a junior dragster Confused Confused Confused
PostPosted: Fri Nov 05, 2010 11:14 am    Post subject: Re: Carbs Reply with quote
After pulling my pump apart a couple of times to try and sort out the fueling,
I can't see anything in it that would need servicing Crying or Very sad
My 6R runs fine without the pump Wink
Brad
PostPosted: Fri Nov 05, 2010 11:41 am    Post subject: me too Reply with quote
Thats what I thought but the junior dragster guys do it regularly apparently maybe the methanol screws something up.
The bit I don't understand is why should taking the pump of change anything? especially the main jet.
Having tested my SB6R I think the carbs are poo anyway, always have been ever since the GSXR1100M had them fitted the throttle response is dire.Injection is the way to go Cool Cool Cool Cool
PostPosted: Fri Nov 05, 2010 11:55 am    Post subject: Reply with quote
That could be it Wink
Methonal screws most things up Wink
PostPosted: Fri Nov 05, 2010 12:46 pm    Post subject: Reply with quote
Injection is the way to go(........along with a turbo Laughing) but the cost is prohibitive to a lot of us.
I can't help thinking (for several years) that these engines would run better on 38mm carbs instead of the 40mm suzuki san gave them. The 40mm seem to over fuel at every point except the very top end .
Brad
PostPosted: Fri Nov 05, 2010 1:12 pm    Post subject: hrottle response Reply with quote
The test to do when on the dyno is to take it to say 6000rpm shut the throttle wait unitil it gets to 5000rpm the snap it open.You'll find that the slides go up too quickly and there's not enough fuel.On the road you'll feel this by what seems like an initial drive then a pause then it'll all comes in,this also makes it feel peaky.On the dyno you can repeat it at 6000,7000,and 8000rpm.
The best carbs for throttle response I've found are the Bandit 36mm jobbies.
The way Suzuki eventually tried to cure this on the 600 and 750 srads was to have dual slide speeds by bleeding the vacuum off the slide with valves connected to the CV carb top.This maintains good throttle response without having to much slide speed at lower rpm.
Adapting a efi system from a GSXR1000 should be easy enough, you just need a rotor to be made the throttle bodies pump etc the hardest part is getting the cam pos sensor on. Cool Cool
PostPosted: Fri Nov 05, 2010 4:44 pm    Post subject: Reply with quote
personaly I'm thinking about rocket power Arrow Arrow Arrow
PostPosted: Fri Nov 05, 2010 4:50 pm    Post subject: Reply with quote
SB power not enough for you any more Laughing
PostPosted: Sat Nov 06, 2010 1:31 am    Post subject: Reply with quote
It'll be find if only I could get some !!!
PostPosted: Sat Nov 06, 2010 10:37 am    Post subject: Reply with quote
So you haven't done that bit of a job yet Laughing
PostPosted: Sat Nov 06, 2010 10:42 am    Post subject: Re: Carb settings on an SB6R Reply with quote
gobert bimota wrote:
Hello
Thanks
This is what works for me........
165 mains
pilots 2 1/4 turns
needle groove 5
fuel pump disconnected
gives 137 rwbhp and 79 torque
Wink
PostPosted: Sat Nov 06, 2010 1:51 pm    Post subject: Reply with quote
Not yet ... but I've got some excuses Very Happy
sb6rdaz
PostPosted: Tue Nov 23, 2010 10:31 am    Post subject: Reply with quote
The 6R doesn't need the fuel pump, and the carbs are fine on that motor. The fuel pump is driven from vacuum in the intake, but is ported from the wrong side of the carbs, so increases/decreases fuelling at the completely wrong time. IE, gives bigger flow on a shut throttle on the overun, and less on a wide open throttle. The GSXR was gravity fed, as was the SB6, so no point in the 6R. Plus the float valves are not strong enough to hold back the fuel pressure, hence all the overfuelling symptoms everyone sees.
The stock carbs can be jetted very well, once all the external influences are taken away, and have mine fuelling spot on, regardless of revs/throttle openings etc. be it on the street, dyno or track.
