Posted: Wed Dec 31, 2014 8:54 pm Post subject: |
doesn't the preload "click" on to the pin in the middle of the adjuster acting on the cartridge ? The blue bolt / screw winds up or down acting on the spacer and spring ?
Possibly _________________ Don't read everything you believe |
Posted: Wed Dec 31, 2014 10:34 pm Post subject: |
That's what I would have thought. In this disassembled photo, doesn't the fork cap wind up and down the blue preload adjuster thread?
Or do what look like pins in the bottom of the fork cap lock them permanently together? |
Planter
Posted: Thu Jan 01, 2015 1:26 pm Post subject: |
I believe that the pins provide the 10mm of preload adjustment by directly acting on a collar sitting on top of the spring. Turning the blue, fork cap adjustment nut alters the amount of preload put on the spring by winding up and down the blue preload adjuster thread.
In the set up in this photo this direct interface between the preload pins and collar seems to be missing as there is the large preload spacer installed that puts a significant air gap between the spring collar and the preload adjuster pins. Also, the nut above the spring collar should be below the spring collar in a standard set up. I can only summarise that the in a previous life these forks were set up for specific use that did not require preload adjustment, and that a shorter spring was installed.
I guess the compression (or is it rebound - I always mix them up) control is using a screw in the middle of the preload unit acting by direct action on the valve in the middle of the cartridge. However, how this process works is not clear even with the parts stripped down. |
Posted: Thu Jan 01, 2015 9:33 pm Post subject: |
OK, I can see how it works now. It look pretty normal apart from the pins hanging down.
The preload spacer above the spring is pretty thick but that's OK. The spring and spacer should together just barely fit below the C shaped clip with just a slight amount of spring compression.
Unless I'm missing something, the preload adjuster will work as normal. The whole blue mechanism including the rod lock nuts, C clip and spacer will all move down when you wind the adjuster in, thereby increasing your preload. |
bikesjohn
Posted: Tue Feb 10, 2015 3:06 pm Post subject: |
I seem to remember that when I needed to fit replacement seals, Kawasaki zx9 (long life) fitted perfectly and are still working after a few thousand miles. |
Planter
Posted: Tue Feb 17, 2015 12:29 am Post subject: |
All fitted. The Kwak ZX9R E2P seals and Honda XR650R bushes seem to do the job. Haven't ridden the bike yet but the forks went back together fine. |
SiBag
Posted: Tue Feb 24, 2015 1:51 pm Post subject: |
Interesting info on the seals.
Will come in handy when I get round to doing the preload mod. _________________ Si...
Planter
Posted: Tue Jun 09, 2015 9:49 pm Post subject: |
Been riding the bike for a few months now. All good - front forks are sound. |
