Posted: Fri Jan 14, 2011 8:32 pm Post subject: |
Your always welcome and you can have a choice of beverages but if you want oil, I'll need advance warning |
Posted: Fri Jan 14, 2011 10:30 pm Post subject: |
Good to see a returning member to the forum, will keep Oiley, Pompey and Evilchicken company. If you look at the events section you will see that GeeKay is organising it and bikes are welcome to be dropped off on the Friday and collected the Sunday, so lenty of track time for you also. If down on the Friday/Sunday, then hope to see you all there |
Posted: Sat Jan 15, 2011 1:00 am Post subject: |
I remember you asking about the FZR400R SP from the PB Forum - Nice to see this will go to a good home _________________ Don't read everything you believe |
Admin Site Admin
Posted: Tue Jan 18, 2011 11:00 am Post subject: |
Evilchicken0 wrote: |
All the FZR motors are maked with "1WG" only (even the 3TJ's) there are no engine numbers as such. |
Yamaha seemed to not use actual engine numbers on any Japanese market bikes. Unfortunately means that even the replacement engine probably has no engine number either.
Keith |
