djt77
Posted: Tue Jan 18, 2011 1:48 pm Post subject: Zombie.... |
Zombie do you have an email address I can reach you on? When I PM nothing seems to get through.
Admin is there any reason my PM's aren't going through to people?
Regards
Dan |
Admin Site Admin
Posted: Tue Jan 18, 2011 4:12 pm Post subject: |
Don't know of any reason why PMs shouldn't get through.
Is the message in your out box or your sent box?
Keith |
djt77
Posted: Wed Jan 19, 2011 1:19 am Post subject: |
Keith,
Some seem to go through but others just sit in the outbox? only happened a couple of times so may be a glitch in the Matrix? Otherwise just get a heading at the top of page saying Invalid Session. Please resubmit the form??? |
Posted: Wed Jan 19, 2011 4:15 pm Post subject: |
FYI - Ive had the invalid session note a couple of times and its always sent OK when Ive resent it. Like now!!! |
Admin Site Admin
Posted: Thu Jan 20, 2011 2:09 pm Post subject: |
The invalid session thing is a bug I am trying to trace down. If you get that when posting then the post probably hasn't gone through.
If it is in the out box then it should be in the recipients in box. Once they have read it then it should land up in the sent box.
For those who are bored and want to know about the sessions issue, the problem is that sometimes the IP address isn't getting passed through. Whenever you do anything on here it should pass back the session id and the IP address, and it checks that both match for the last time you did anything. If not it assumes you are trying to hack in and bounces you off. As such if the IP address is not passed back (it comes back as 3 colons) then you are bounced off. Not sure what is causing it, but it does seem to happen to some people more than others and also seems to occur in bunches
If I can't fix it then I will have to move the board onto another server.
It is not the board software, it is somewhere in the server software but our web space provider can't find the issue.
Keith |
