Barrels & Pistons
PostPosted: Wed Jan 19, 2011 7:25 pm    Post subject: Barrels & Pistons Reply with quote
Looking for a Good set of pots and slugs for a SB6 or GSXR1100w
Would possibly buy complete engine.
Already looked in the usual places so any leads gratefully accepted Wink
PostPosted: Wed Jan 19, 2011 9:59 pm    Post subject: Reply with quote
I've got some pistons
PostPosted: Thu Jan 20, 2011 10:11 am    Post subject: Reply with quote
Thanks, I'll keep it in mind Wink
Pistons are an eaiser problem to sort than barrels.
What size pistons did you throw in your engine, standard size?
PostPosted: Thu Jan 20, 2011 10:30 am    Post subject: Reply with quote
Nope same as yours JE Pistons to give 1147cc
PostPosted: Thu Jan 20, 2011 10:33 am    Post subject: Reply with quote
Can't believe I nearly missed a chance to piture whore then !!!
PostPosted: Thu Jan 20, 2011 10:38 am    Post subject: Reply with quote
shame i can't see the pictures here at work Laughing
Are you still on standard liners?
If so, I'll wait and see what's wrong with yours Laughing
PostPosted: Thu Jan 20, 2011 2:07 pm    Post subject: Reply with quote
Yes I had the standard liners rebored for the pistons.
You could always come down on the train for the weekend and "see what's wrong" for yourself ... might need to help taking the engine out though Laughing
I'm thinking something in the valve train as the tick is at half revs.
PostPosted: Fri Jan 21, 2011 10:37 am    Post subject: Reply with quote
Unfortunatly, I have a morbid fear of train travel Laughing
A small blow from one of the headers would sound like a ticking and would also be half engine speed Wink
PostPosted: Fri Jan 21, 2011 12:08 pm    Post subject: Reply with quote
ok - as I say I'll have a look when I take them off.
CBar
PostPosted: Fri Jan 21, 2011 10:34 pm    Post subject: Reply with quote
What else is required to do this? Balancing?
PostPosted: Sat Jan 22, 2011 12:23 am    Post subject: Reply with quote
Just a re-bore +2.5mm
The JE pistons are matched better than the OE pistons and much lighter Wink
PostPosted: Sat Jan 22, 2011 2:32 am    Post subject: Reply with quote
Yes but you'd probably have the head cleaned up, flowed and the valves lapped.
I put in some Kent Cams and had the parts Camcoated to control the heat in the combustion chambers.
There's a size higher up which needs new liners and the engine casings to be machined for them.
You can also fit the GSX-R750W gear ratios to give you a 6 speed box.
The biggest problem with the SB6 is the airbox though, it's to small for the engine to breath fully which is why you could consider 38mm carbs.
