SB6 Speedo drive on front wheel
bruce
PostPosted: Mon Jan 24, 2011 7:02 pm    Post subject: SB6 Speedo drive on front wheel Reply with quote
I need help? 1996 SB6. My speedo drive body has cracked. Is this a standard (Ducati?) item? or a similar italian source?
Any help appreciated in getting a replacement. Thx.
PostPosted: Tue Feb 01, 2011 9:08 pm    Post subject: Reply with quote
Seems no body knows the answer to that bruce
Mine look like gsxr items but without pulling a front wheel out and measuring the spindle......
If it is a gsxr item, I've probably got one some where Wink
PostPosted: Tue Feb 01, 2011 11:04 pm    Post subject: Reply with quote
I though Yamaha .... maybe both manufacturers used the same supplier afterall it's a 120/65 17 tyre and most bikes use that.
You can use a Yamaha speedo cable, they don't break as easily as the Suzuki ones.
CBar
PostPosted: Wed Feb 02, 2011 2:28 am    Post subject: Reply with quote
I'm pretty sure you can use one from a Ducati with a 25mm axle. 916-998. Also 900ss '99+.
bruce
PostPosted: Wed Feb 02, 2011 9:58 am    Post subject: speedo drive information Reply with quote
Thank you gentlemen.
I was thinking around the Ducati speedo idea.
It looks similar.
I would imagine they'd source it within country.
I'll drop it into a Ducati agent and see what they have to say.
Thx. Ken Bruce
CBar
PostPosted: Fri Mar 04, 2011 10:35 pm    Post subject: Reply with quote
It might be too late now, but I passed on some bad info that was passed on to me. I measured my front axle the other night and you need speedo drive for a 20mm axle. Check the earlier 900SS (93-98 ).
bruce
PostPosted: Tue Mar 08, 2011 12:56 pm    Post subject: Reply with quote
Thx. I'm tackling a boiling problem at the moment,. I'll track down the 20mm drive when i can stop making roadside tea from the cooling system. Much appreciate the advice.
the GSXR 1100 isn't the cap they used..Just another 25,000 rad caps to try -
PostPosted: Tue Mar 08, 2011 1:18 pm    Post subject: Reply with quote
Oh dear, I'm hoping it's not what I think it is Crying or Very sad
Don't think the rad cap will make too much difference to boiling on this system
PostPosted: Tue Mar 08, 2011 1:20 pm    Post subject: SB6 Speedo Drive Reply with quote
Don't bother looking for a replacement rad cap, you'll never find one. You need to get a new neck made up that will take one of the readily available caps.
