removal fuelpump
veloviper
PostPosted: Sun Apr 10, 2011 7:17 am    Post subject: removal fuelpump Reply with quote
Goodmorning,
I have a Bimota BB monoposto. The problem is a thin layer of black sludge in the petrol tank. This sludge clogs the carburateurs.
I like to clean and coat the petrol tank . But it is unclear how to remove the fuelpump. Do you need a special tool to remove the pump?
Please advise on this problem if possible.
Thank you,
Regards,
Henk Draaiman
Netherlands
veloviper
PostPosted: Mon Apr 11, 2011 6:59 am    Post subject: remove fuelpump Reply with quote
I tried mailing the factory but info@bimota.it is out of action.
(non-existent hosts or (invalidly) to IP addresses)
Anyone got a current mail adress from Bimota?
PostPosted: Mon Apr 11, 2011 9:45 am    Post subject: Reply with quote
Try a private message to the member "UKBimota" they might be able to help you contact Bimota, but they're unlikely to reply.
I don't what your tank is made of so I don't know what the sludge is ... however there were a couple of bikes that had something similar happen - it could have been the SB forum - I think they washed out the tank and used new fuel.
atomibart
PostPosted: Mon Apr 11, 2011 9:56 am    Post subject: Reply with quote
Good morning,
I had the same problem recently.
To remove the fuel pump you have first to remove the three plates at the rear of the tank (in front of the swing arm) which are the electric. connections of the fuel pump and a floater.
Then you have to remove the round metal plate at the bottom of the tank (be careful : all the remaining fuel will drop) and after that remove very carefully the fuel pump. You may have not only to clean the tank but also the fuel pump, and to change the rubber ducts immerged in the fuel (I bought special rubber made for this at a BMW garage).
FYI after doing this I also clean the carburettors... And once built up again the bike still does not idle...
Good luck and sorry for my poor technical english
atomibart
atomibart
PostPosted: Mon Apr 11, 2011 9:58 am    Post subject: Reply with quote
To reply furthermore to your question : no special tools required, just patience
veloviper
PostPosted: Tue Apr 12, 2011 10:00 am    Post subject: Reply with quote
Thanks for your help Smile
atomibart wrote:
Good morning,
atomibart
veloviper
PostPosted: Wed Apr 13, 2011 6:55 am    Post subject: Reply with quote
yes, the thin black layer of goo is the fuel hose from the pump dissolving in the petrol....
nice one Sad
