dougk
Posted: Tue Jun 28, 2011 9:40 am Post subject: New clocks for a YB11 |
Does anyone have a working set of MPH clocks for a YB11?
or does anyone know if you can change the instruments for a digital set? I have seen one yb11 with a new digi set on...
thanks in advance
Doug |
dougk
Posted: Tue Jun 28, 2011 11:51 am Post subject: |
do you know which set it is?
thanks again |
Posted: Tue Jun 28, 2011 12:39 pm Post subject: |
Oops having had a look at the db5 clock it's not the same ... the DB7 however ... looks like the RX2 model.
You will need some of the add on sensors like the inline temp and maybe a speed sensor depending on what you have already _________________ Don't read everything you believe |
