jatexup
Posted: Sat Jan 24, 2009 7:19 pm Post subject: SB8R gear linkage woes |
Hi,
Whilst out on my SB8R today, when attempting to change down through the gears the carbon-fibre gear linkage rod became disconnected from the lever attached to the gearbox sprocket. Upon closer examination when I arrived home (albeit still in 5th gear!), it was clear that the bolt in the metal rose joint on the end of the c/f rod which attaches it to the lever had sheared off, leaving part of it inside the lever!
If anyone has such items I'd be extremely grateful. Unless I can get a spare lever/rod unit then I'll attempt to get the existing one sorted by drilling out the broken-off bold and getting the gear lever re-threaded, and see if I can get the other bit sorted so that it might be possible to get the rose joint end of the bolt out of the bit that unscews from the c/f rod, or indeed get one made up if necessary. Here's hoping anywasy!. |
madasfook
Posted: Sun Jan 25, 2009 8:59 am Post subject: |
i did try and get a carbon link rod from the factory but they do not stock them any more , luckly i still have the good old alloy one  _________________ so many toys so little time |
Posted: Sun Jan 25, 2009 11:07 am Post subject: |
The gear lever, isn't it a TL1000 item? and an alloy rose jointed rod, no problem to get made  |
madasfook
Posted: Sun Jan 25, 2009 12:01 pm Post subject: |
the alloy replacement number is 505182680 or for the carbon one is 505182080 if you email the factory they do have quite a good spaires dept  _________________ so many toys so little time |
jatexup
Posted: Sun Jan 25, 2009 12:57 pm Post subject: SB8R linkage |
Hi guys,
Thanks very much for your extremely helpful and swift responses - it's very much appreciated.
Best regards,
John |
