mainstone41
Posted: Tue Mar 27, 2012 11:32 pm Post subject: New play thing is in bits! |
Spent a fortune, It dont run and now i have it in bits! Bimota ownership is wonderful, yay! lol. Hope to have the my new purchase running tomorrow.. but dont hold me to it! |
Posted: Wed Mar 28, 2012 7:56 am Post subject: |
Yep, that's Bimota ownership
Good luck  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Mar 28, 2012 4:04 pm Post subject: |
You do a lot of miles in the garage  _________________ Don't read everything you believe |
akito-man
Posted: Wed Mar 28, 2012 6:26 pm Post subject: |
Mayn;(, hope its sorted soon buddy!) _________________ wot you got ?...me..well--
mainstone41
Posted: Wed Mar 28, 2012 7:37 pm Post subject: |
Carbs stripped rebuilt and balanced (not pouring fuel out number 3 carb now), perished coolant hose replaced just need a fuel tap or diaphragm to be on the road!! |
Posted: Wed Mar 28, 2012 9:13 pm Post subject: |
good its not too bad........ |
Posted: Wed Mar 28, 2012 9:36 pm Post subject: |
Typical Bimota...........
one step forward and two steps back
You'll get there, and then it'll all be worth it  _________________ SB6 mk1 (project mega light, big bore)
mainstone41
Posted: Thu Mar 29, 2012 10:22 pm Post subject: |
Hopefully diaphragm on way soon so not long now till i can take her for a spin! I have managed to find out about a fuel tap overhaul kit, just waiting on price and availability from abroad so fingers crossed, will share with all if deal comes off! |
Posted: Thu Mar 29, 2012 10:24 pm Post subject: |
Good man, order two  _________________ SB6 mk1 (project mega light, big bore)
mainstone41
Posted: Tue Apr 03, 2012 5:26 pm Post subject: |
Bike running replacement fuel tap on, sweet! Thanks to Evilchicken. But being a Bimota the cooling fan does not want to cut in so nissan sender to order tomorrow, D'oh! One day my beauty i will ride you, one day. |
Posted: Tue Apr 03, 2012 6:08 pm Post subject: |
Oh the joys of Bimota ownership  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Apr 04, 2012 3:37 am Post subject: |
mainstone41 wrote: |
Are you sure it's the sender? Have you shorted the fan wires at the switch to see if the fan goes? The standard suzuki switch doesn't cut in til 105 deg Cand cuts out again at 100 deg C. Some more info in this thread -
http://www.bimotaforum.co.uk/viewtopic.php?t=1070&postdays=0&postorder=asc&start=0 _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
mainstone41
Posted: Wed Apr 04, 2012 6:11 am Post subject: |
Have put a feed direct to the fan and it works i then shorted out the sender wiring and again the fan works but run the bike and it goes into the red with no go on the fan! |
Posted: Wed Apr 04, 2012 7:25 am Post subject: |
Yep, mine goes into the red before it starts too. Only starts if stuck in traffic or at the lights. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Wed Apr 04, 2012 12:42 pm Post subject: |
I have the same problem, so I had the question, what's wrong. First I tested the fan sensor, and that was okay. Then the temp sensor and that was also okay. Only then there is the temperature indicator. According to this forum is usually the indicator that is not reliable. The next step was to test the indicator, so I had to find a resistor, and preferably an adjustable resistor. How this would be solved by MacGyver........ ..... grabs my radio pulled it apart, and there it is an adjustable resistor. (The music will not be mist, almost deaf on one side). Now, according to the manual I performed the tests, and the results are shown in the drawing and photographs.
Conclusion, indicator deviates.
Solution, you can accept that the needle is in the red, you know it does not hurt until the needle indicates max.
Or to place a resistance of 8 ohms between the indicator and sensor. So you shift the reading a little back.
Why 8 ohms, if the sensor measured a temp of 105 °C the resistance is approx 24 ohms. That’s approx the same temp when the fan kicks in.
The reading is now at the end of the white surface of the indicator. Will the temp go higher then you know that the fan can not handle it.
I’m now testing it and it seems to by working.
How do you smart people think about it, if I’m wrong please tell me. I can only learn from it
Sorry, I could not make the text shorter.  |
