DB2 Battery
madasfook
PostPosted: Sat Aug 08, 2009 12:42 pm    Post subject: DB2 Battery Reply with quote
Hi does anybody know the size battery i need for my DB2, bought a 900ss one but it was to big Mad Mad fugit
so many toys so little time
PostPosted: Sat Aug 08, 2009 10:05 pm    Post subject: Reply with quote
You could always get a db1 to wrap around it? Shame for it to go to waste... Oh and send me your mob. no. again, I cant find it for some wierd reason, cheers john.
madasfook
PostPosted: Sun Aug 09, 2009 7:32 am    Post subject: Reply with quote
thats not realy a help , i could go to CMS with the battery box sizeand see what they can do , if anybody needs a 900ss battery i have one Very Happy
GavleStefan
PostPosted: Thu Aug 27, 2009 2:36 pm    Post subject: Reply with quote
If, only if I remember this correctly it should be YTX14AH-BS I think.....
That is a sealed variant that I fitted on mine.
Original , again I think is: YB14-A2
I can check it tomorrow if you want.
Stefan
I'm not stupid, but occasionally I've bad luck when I'm thinking.....
madasfook
PostPosted: Thu Aug 27, 2009 3:58 pm    Post subject: Reply with quote
thanks for that Stefan
Catimann
PostPosted: Sat Mar 12, 2011 8:40 pm    Post subject: Speedwell battery Reply with quote
I know this is an old post but I am looking at all the posts as I am new here.
Have you guys read or seen Speedcell batteries?
http://www.e-securedsite.com/motowheels/ITALIAN/myProducts.cfm?parentcategoryid=915%7CBatteries%20and%20Battery%20Accessories&productID=6814&showDetail=1&categoryID=915%7CBatteries%20and%20Battery%20Accessories&vendoridtodisplay=0&filterFor=&collection=
Andreas
93 DB2SR, 74 MG Eldorado, DRZ400SM
Searching for Tesi ES or EF
redtop
PostPosted: Mon Mar 14, 2011 3:39 pm    Post subject: Re: Speedwell battery Reply with quote
Those are LiFePo4 cells. Several friends have been riding the last season with such packs (homebrew though), and they have been satisified.
You can get quality packs of Ebay at a muych better price e.g:
http://stores.ebay.com/OMG-Battery/Motorcycle-Start-Battery-/_i.html?_fcid=192&_fsub=1297677014&_jgr=0&_localstpos=&_sid=450554384&_stpos=&gbr=1
Another alternative is Shorai who puts LiFePo4 cells in plastic cases with the same size as standard motorcycle batteries. Plug and play, and price less than half from "Speedcell".
http://www.shoraipower.com/
RedTop
DB2 #300
Anders
PostPosted: Fri Mar 18, 2011 4:17 pm    Post subject: Reply with quote
I bought a Durbahn LiFePo4 A123-based battery pack a year ago. The intended usage was as a BB1 Supermono battery, but haven't got around to mounting it in my Supermono yet. I'll have to figure out where to put it, as I'm quite sure the standard batterybox (oil tank) will be to hot. I have used it as a HID helmet lamp battery for winter night-time enduro riding though. 2 hours of 35W HID power in less than one kg of battery is not bad at all.
The only drawback I can think of using these batteries, is that you need a LiFePo4-compatible charger if you want to treat the batteries right (balancing them from time to time).
Anders
bb1, Stark Varg EX, Ducati Mille S2, Guzzi / Watsonian, Morini Corsaro 125, EC200, RD350YPVS etc
Catimann
PostPosted: Thu Mar 24, 2011 5:12 pm    Post subject: Reply with quote
Thats good info. Mine has been sitting for over a year, no charge up nothing. What is a good charger for these things?
Andreas
Anders
PostPosted: Fri Mar 25, 2011 6:37 am    Post subject: Reply with quote
I have a Hyperion EOS 0606i charger, one of the smaller in the Hyperion range.
http://media.hyperion.hk/dn/eos
However, to be able to use this charger for balancing, the battery must have a balancing connectector. My battery (Durbahn) has this connector, but I am not sure if this is true for all types. The balancing connector is usually a small multipin connector with 5 thin wires attached, like you see in the link below.
http://shop.durbahn.de/shop/en/jsp/largeimg.jsp?product_id=708
