Posted: Sat May 19, 2012 6:58 pm Post subject: |
There you go. One of our 3 mechanics strikes again... Evil, Oily and Lami... _________________ Pomps
jakoblt
Posted: Sat May 19, 2012 8:56 pm Post subject: update |
thanks to all of you.
I took all connections a part and sprayed them with a spray that make water go away after that I used electrician tape and silicon grease on all wirering that i could get to
When I took the wirering of the fuse box there were water running out.
After that I putted a little additive "alcohol" in the gas. Then i took a cup of coffe and hoped.
The result was that it actually started and starts better now then ever
Ps I checked the airfilter and there were now water and checked the tank
brgds
Jakob |
Posted: Mon May 21, 2012 2:07 pm Post subject: |
Sounds like the it could have been an acumilation of all the block connectors. I don't like the adhesive electricians tape, it turns into a sticky horrible mess after a short while - us self amalgamating tape but make sure you don't get you fingers all over it or it won't work.
The fuse box is probably why the bike stopped, the water could have shorted to earth. _________________ Don't read everything you believe |
jakoblt
Posted: Wed May 23, 2012 7:44 am Post subject: self amalgamating tape |
Hi evil,
Would it be to much to ask you maybe to link to a page where they sell that atpe you write about ? I dont know what it is but maybe I can find it in denmark when i know what it is hope it make sense.
thank you for the help
brgds
Jakob |
Posted: Wed May 23, 2012 10:45 am Post subject: |
self amalgamating tape can be purchased from any good electrical supplier.
It is tape that "fuses" to it's self  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed May 23, 2012 10:52 am Post subject: Re: Fuses |
jakoblt wrote: |
I finally got the bike a part. It is the fuse for "injection system protection" has anybody got an idea what to do. I Will of course install new fuse but what then?
Brgds
Jakob |
Two things spring to mind.......
The first is...Don't use an Italian bike in the rain
Secondly...Use WATERPROOF fuse holders with a smear of petroleum jelly on the seals (Vaseline is for medical or sexual uses not Bimota uses EC ) _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed May 23, 2012 1:48 pm Post subject: |
Vaseline is a petrolium jelly - not for sexual use.
You should use a waterbased lube ....  _________________ Don't read everything you believe |
Posted: Wed May 23, 2012 1:51 pm Post subject: |
Vaseline is a STERILE, ANTI-BACTERIAL petroleum jelly......
Have they not done the "must be accurate" lesson at college yet  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed May 23, 2012 6:40 pm Post subject: |
It reacts with latex so you'd keep it away from standard condoms. _________________ Don't read everything you believe |
Posted: Wed May 23, 2012 6:51 pm Post subject: |
Evilchicken0 wrote: |
It reacts with latex so you'd keep it away from standard condoms. |
noooooooo
you've now gone too far...too much information  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed May 23, 2012 11:43 pm Post subject: |
And strap-on dildos .... they're like bar grips, think about it next time you're riding  _________________ Don't read everything you believe |
Posted: Thu May 24, 2012 11:47 am Post subject: |
And strap-on dildos .... they're like bar grips, think about it next time you're riding  |
That's it...that's the end
any body want to buy a big box of SB6's
jakoblt
Posted: Thu May 24, 2012 12:57 pm Post subject: Calm Down :) |
I Will find That tape. Regering vaseline i have not used it on my bimota i used silicone grease to seal All fuses and boxes and connections:) |
Posted: Thu May 24, 2012 1:13 pm Post subject: Re: Calm Down :) |
jakoblt wrote: |
Good choice, stay away from Vaseline(and evilchicken ).
Silicon grease is the correct "stuff" to use  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu May 24, 2012 2:02 pm Post subject: |
Always here to help  _________________ Don't read everything you believe |
