pdcooper
Posted: Tue Jul 31, 2012 5:36 am Post subject: SB8R Fuel Pump |
Any idea where I can buy one of these?
Is it used in any other vehicles? |
SB8R Tuner
Posted: Tue Jul 31, 2012 4:00 pm Post subject: |
SB8R fuel pump is a 5 Bar unit, not 3 Bar. |
pdcooper
Posted: Fri Aug 03, 2012 3:47 am Post subject: |
This is not a $350 pump....
It is a Walbro....I am sure it is a $100 pump used somewhere else.
The question is where else... |
Posted: Fri Aug 03, 2012 6:27 am Post subject: |
exactly I think not a 350$ pump too.
I've just fitted a 'sock' to a second hand BMW K1200 pump so that it can fit in the tank of my 851, much cheaper than getting another 52mm diameter Bosch or whatever pump.
post a pic of yours so we can have a look.
I understood that even though all of the pumps listed on euromotoelectrics are rated at 3 bar they normally have a cut out a 6 bar. It could be that Bimota made use of that feature by turning up the fuel regulator. That was a racing trick also used by Ducati to get a bit more fuel in. Sounds a bit risky for a road bike though.
Best bet is to talk to a good injection shop.
If you are in the US, it at least seems that the prices you have to pay over there are quite a bit less than prices in Europe. Even for European products!
all the best
http://thecrankcase.com |
Posted: Fri Aug 03, 2012 6:41 am Post subject: |
here's a search I did for Walbro pumps on the Ducati forum:
http://www.ducati851and888.com/search.php?searchid=20039
lots of info, but Ducatis run at 3 bars.
Question is- do you need a '5 bar' pump or is it down to the fuel pressure regulator??
again best to talk to a good shop I think. _________________ Bimota DB2 tricolore, Bimota YB4e.i, Ducati 851 tricolore, Ducati Hailwood Replica, 1968 Gitan Grillo sport, Yamaha GTS1000, Honda Deauville, Honda GB500 Clubman
SB8R Tuner
Posted: Fri Aug 03, 2012 4:52 pm Post subject: |
Fuel pump puts out more than 5 Bar, how much I do not know. The fuel pressure regulator is a Weber product. The part number is RPM73 and regulates it down to 5 bar. The only reason I can think of for such a high fuel pressure is to keep the duty cycle down on the injectors. |
Posted: Fri Aug 03, 2012 5:35 pm Post subject: |
Ducati used twin injectors per cylinder on the high spec models for racing, obviously they only had a limited time to get enough fuel in for a half litre pot making 180 plus HP per litre. Running a higher pressure helped out with that.
Sorry I don't know how many injectors are on the SB8. Could be the same problem. That's why the 5 bar.
I know the Santamonica has shower injectors, are they the only ones or is it 2 stage. My god it's complicated.
But surely the latest injectors also flow a lot more than the old Weber units.
I reckon the best way still to find a suitable pump is to talk to a good shop and get an equivalent spec one. _________________ Bimota DB2 tricolore, Bimota YB4e.i, Ducati 851 tricolore, Ducati Hailwood Replica, 1968 Gitan Grillo sport, Yamaha GTS1000, Honda Deauville, Honda GB500 Clubman
zombie
Posted: Sat Aug 04, 2012 11:38 pm Post subject: |
Just for info, Sb8k Gobert and SM run on just one injector per cylinder and the pressure is about 3.5 bar too, yes same as Ducati 1098, 999, 1198 (ducati actually copied the SB8K shower injectors then added two more for low speed is my guess)
The other difference is that on the 8R the FP regulator is internal to the pump assy unlike the K and the ducatis where the fuel flows out and is regulated by its passage back into the tank.
I would hazard a guess that the 8R would run fine on a lower pressure pump I would say that the high pressure is an optimistic assessment by bimota of what positive intake pressure the RAM air was going to add and hence the injectors would have to fight against ? |
