Posted: Wed Aug 08, 2012 7:44 pm Post subject: |
sounds most likley you have either glazed the bores when its was first "run-in" or not as the case may be or the hone on the bores is no good and has potentially damaged the oil scraper ring............. |
Posted: Fri Aug 10, 2012 7:22 am Post subject: |
Well.........we're still waiting for pictures
your sb7 problems.....until the engines pulled apart (yet again) it's all speculation but as the steam seals have been replaced it's most likely a ring/bore issue and yes, you may have used a too good quality oil
your Kwacker problems........stick um on a kwacker forum  _________________ SB6 mk1 (project mega light, big bore)
Mike Jennings
Posted: Fri Aug 10, 2012 9:14 am Post subject: |
Piston rings upside down?
Cheers, MikeJ |
bob
Posted: Fri Aug 10, 2012 2:03 pm Post subject: |
Thanks for the posts. I'll post the photos over the weekend as I'm away working just now. No photos of the green meanie though :cry: |
Posted: Sat Aug 11, 2012 2:16 am Post subject: |
bob wrote: |
Thanks for the posts. I'll post the photos over the weekend as I'm away working just now. No photos of the green meanie though  |
A photo of the green meanie would be perfectly above board provided there's a bimota in the background . I have a fondness for all things green, especially kwakas.  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
bob
Posted: Sat Aug 11, 2012 4:05 pm Post subject: |
I'll up load the files now if someone can tell me how please? I don't know if I'm having finger trouble or what. PS (its a mac if that makes a difference?)
Thanks. Bob.[/img] |
Posted: Sat Aug 11, 2012 4:56 pm Post subject: |
You have to host your images on line ... try opening a photobucket account. Upload your pics to an album, copy the "direct link" code. Then in the reply dialogue box hit the Img shortcut paste the link and press the Img* again.
That should do it.[/img] _________________ Don't read everything you believe |
bob
Posted: Sat Aug 11, 2012 5:45 pm Post subject: |
Photos - hopefully!
bob
bob
Posted: Sat Aug 11, 2012 6:04 pm Post subject: |
Thanks for your help Mr E.Chicken |
Posted: Sat Aug 11, 2012 6:18 pm Post subject: |
Lovin the SB7 bob
When you've finished playing with it, just pop it down to the midlands and I'll take it off your hands
That's a late registered SB6
Glad to see your not frightened to use it  _________________ SB6 mk1 (project mega light, big bore)
bob
Posted: Sat Aug 11, 2012 6:38 pm Post subject: |
Don't think I could afford the oil to get it all the way down there!!!!
Still hopefully have that fixed soon thanks to the Forum.
The sb6 has now got carbon dymags fitted - but I don't seem to have any photos of them and the bike is at the back of the garage - probably laid up for winter now!!!!
Cheers. Bob. |
bob
Posted: Sat Aug 11, 2012 6:41 pm Post subject: |
Just on using the sb6 - last time I took it to Assen it broke down!!! The cush drive between the engine and alternator ringed out. Had to take it trailered back. And there was me thinking the gsxr1100 engine was built-proof. Still managed to fix it without taking out the engine. |
Posted: Sat Aug 11, 2012 6:51 pm Post subject: |
bob wrote: |
Don't worry bob, I'll pay for the oil  _________________ SB6 mk1 (project mega light, big bore)
bob
Posted: Sat Aug 11, 2012 7:12 pm Post subject: |
Oily - your post about the long bolts touching the engine - guess the answer is such to add a washer or two?? |
