91 Bimota YB10
AltoBimota
PostPosted: Fri Sep 07, 2012 9:36 pm    Post subject: 91 Bimota YB10 Reply with quote
I have a 91 YB10 and it's developed a problem. When it is started cold it runs great. After about 15 minutes once everything is hot the bike begins to stumble when you come to a stop. The idle is very rough and the bike usually stalls when I attempt to pull out from a stop. I've had the carburetor cleaned and checked/adjusted but the problem persists. Can anyone suggest where to look from here?
Thanks!
PostPosted: Fri Sep 07, 2012 10:15 pm    Post subject: Reply with quote
Have you changed the fuel filter.
AltoBimota
PostPosted: Sat Sep 08, 2012 7:30 pm    Post subject: Reply with quote
Carbs cleaned and adjusted, fuel filter replaced, and spark plugs replaced. Almost seems like an electrical issue. Perhaps something breaking down under the heat. Just looking for suggestions. Anyone have any ideas?
PostPosted: Sat Sep 08, 2012 10:26 pm    Post subject: Reply with quote
Change the plugs. One foul plug and you'll get those symptoms...fingers crossed.
PostPosted: Sat Sep 08, 2012 10:54 pm    Post subject: Reply with quote
Here's an odd one - just check the sidestand springs are ok and if the small one has broket replace it
PostPosted: Sat Sep 08, 2012 10:56 pm    Post subject: Reply with quote
Thats another good call evil chuck ... could be the cutout.
PostPosted: Sat Sep 08, 2012 11:02 pm    Post subject: Reply with quote
Innit - and how we laughed after we found that
AltoBimota
PostPosted: Sun Sep 09, 2012 2:05 am    Post subject: Reply with quote
The sidestand spring seems fine. As far as it pulls the stand back rapidly.
But I'll have a look and let you know.
PostPosted: Sun Sep 09, 2012 9:04 am    Post subject: Reply with quote
i am sticking with plug failure Wink
PostPosted: Sun Sep 09, 2012 4:14 pm    Post subject: Reply with quote
I'd go with possible HT leads, bad connection, unscrew each end for the plug caps and if you have spare length trim the ends of and remake the joins, as the plug caps simply screw into the bare wire ends and perhaps one of them just isn't making a proper connection, thus intermittent spark, but if after running you could check this by pulling the plugs and seeing if any are wet with uncombusted fuel?
PostPosted: Sun Sep 09, 2012 6:43 pm    Post subject: Reply with quote
Keep it simple one obvious thing at a time such as plugs Wink
PostPosted: Sun Sep 09, 2012 7:04 pm    Post subject: Reply with quote
Hello Oily, sent you a couple of PM's on Friday?
PostPosted: Sun Sep 09, 2012 7:14 pm    Post subject: Reply with quote
I'm aware.
PostPosted: Sun Sep 09, 2012 7:16 pm    Post subject: Reply with quote
oily wrote:
I'm aware.
Hello Ware
