Posted: Wed Sep 19, 2012 9:31 am Post subject: Disc's anyone |
Gents.
I am about to order some bits from Italy and can get brembo front disc for about £220 a pair and Bimota specific rear disc for about £70 each. These are brand new . Depending on numbers the price may change slightly, postage etc .
If any one is interested let me know in the next few days.
Front are 320mm dia, off db4/5/6/7, SB8K etc.
OR vdue 10 rivet for speedo.(black only, and last few)
Posted: Wed Sep 19, 2012 9:38 am Post subject: |
Definitely up for a rear disc vort and I'm assuming the fronts will fit the later SB6....if so, I'd better have a pair of those too please  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Sep 19, 2012 10:08 am Post subject: |
Bolt pattern is as 916, so yeah fit later SB6 set up.
What colour, you after black for the carbon wheels ? |
Posted: Wed Sep 19, 2012 10:19 am Post subject: |
changed mind......
gold please......to go with the callipers and lighten the darkness  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Sep 19, 2012 3:04 pm Post subject: |
| oily wrote: |
changed mind......
gold please......to go with the callipers and lighten the darkness  |
Changed my mind again vort
Think your right....black discs to go with the carbon wheels please  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Sep 19, 2012 3:29 pm Post subject: |
Technically it's the carriers that are gold or black, not the discs  _________________ Don't read everything you believe |
Posted: Wed Sep 19, 2012 3:33 pm Post subject: |
I really don't know what to say to that ........ except......I pity your wife  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Sep 19, 2012 3:34 pm Post subject: |
oh....and.....get your bike on the register  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Sep 19, 2012 3:37 pm Post subject: |
I'll have to check the offset on the YB's. I'd be interested in a new set of fronts, depending on the carrier/offset, etc.
I do know that 320mm discs are fitted from factory on the YB4, etc _________________ Bimotas, Yamaha FZR 2TK, Honda NC30, MV Agusta F3 800, Aprilia RS250 |
MARTIN
Posted: Wed Sep 19, 2012 3:54 pm Post subject: |
Brembo 320`s for £220 a PAIR , I definatelly want a pair,gold, for SB6
ANTERRA wheels, count me in. _________________ Marty
Og
Posted: Wed Sep 19, 2012 6:59 pm Post subject: |
Will they fit my 94 Mk1? One brake disc is warped, not sure how or why, it happened one night on a run home? Can the existing disc be ground straight? Is that a daft question? All response appreciated!!! Og  _________________ Current Bikes: SB6 Crescent; SB6 (red and white); SB6 (Not red and white) |
Posted: Wed Sep 19, 2012 7:33 pm Post subject: |
No, they won't fit a Mk1 fitted with oscom wheels. They need a much larger offset disc.
As for grinding discs.....depends on how much they are warped.
must be easier to source new discs or have some roters cut to fit your carriers  _________________ SB6 mk1 (project mega light, big bore)
Og
Posted: Wed Sep 19, 2012 7:55 pm Post subject: |
Thanks Oily.I will make a plan.Og  _________________ Current Bikes: SB6 Crescent; SB6 (red and white); SB6 (Not red and white) |
Posted: Thu Sep 20, 2012 11:23 am Post subject: |
So thats :-
Rear
Oily x 1
Front
Oily x 1 Black
Martin x 1 Gold.
Lammie. From memory the offset of the 916 style ones is 10mm, but will measure PCD etc tonight. |
Posted: Thu Sep 20, 2012 11:35 am Post subject: |
Vort, I'm assuming that the black V-due discs are the same (916) fitting as the gold? _________________ SB6 mk1 (project mega light, big bore)
