Non starting SB6
Goto page Previous  1, 2
PostPosted: Sat Feb 23, 2013 12:13 am    Post subject: Reply with quote
Vince186 wrote:
Can you make a picture of the K&N airfilter please Question
I'm curious about that filter..
...Here you go Vince...Sibag's airfilter Wink
Cool
PostPosted: Sat Feb 23, 2013 12:24 am    Post subject: Reply with quote
SiBag wrote:
Think I'll try a MotoBatt, standard GSXR 1100 WR fitment possibly. Try one rather than the usual 2 x 6amp jobbies.
I'll keep you posted on the battery front.
On another front I have noticed my Bim appears to be a little different from standard. Airbox has had the mod with both sides cut out. But it is fitted with a cotton / gauze pleated air filter. Looks like a K and N ?
Fuel tap is a 2 outlet jobby, is this standard?
Cheers for the help.
Yes, fuel tap is vacuum operated duel outlet...
Batteries are YTX7L X 2. They are a snug fit so check the dimensions and find one or two batteries no larger. You will be limited to what you can fit.
Wink
PostPosted: Sat Feb 23, 2013 8:09 am    Post subject: Reply with quote
Cool
Thanks Oily,
Can you tell me the part number what K&N used Question
vince
PostPosted: Sat Feb 23, 2013 8:14 am    Post subject: Reply with quote
[quote="oily"]
Wink
Or use a one lithium battery Wink Laughing
vince
PostPosted: Sat Feb 23, 2013 9:11 am    Post subject: Reply with quote
[quote="Vince186"]
oily wrote:
Wink
...Which seems to be the future...
A totally different technology to lead/acid with a massive weight saving....if you can get your head around the cold weather starting procedures and do's and don't's of the charging procedure and the enormous initial investment....
...then it's got to be the way to go Wink
PostPosted: Sat Feb 23, 2013 10:41 am    Post subject: Reply with quote
Cool
Thanks Oily,
There isn't a part number you have to get a flat filter, then cut and shut it
PostPosted: Sat Feb 23, 2013 11:06 am    Post subject: Reply with quote
[quote="oily"]
Vince186 wrote:
oily wrote:
Wink
Cold weather Question Question What's that Question Laughing
PostPosted: Sat Feb 23, 2013 11:08 am    Post subject: Reply with quote
[quote="brian"]
oily wrote:
Vince186 wrote:
oily wrote:
Wink
I feel for you Brian...never having the experience of cold weather. Such a limited existence Laughing
Page 2 of 2
