Posted: Tue Feb 23, 2010 1:49 pm Post subject: |
Just jam the sprocket with a lump of wood and shock the nut off with an air wrench. Never had a nut resist yet  |
Posted: Tue Feb 23, 2010 6:54 pm Post subject: SB6 Chain |
I'll bring the next one to you - mind you, if there is a next one, 'er indoors is likely to cut my small parts off, so do you do A&E as well?  _________________ What, Jonny's gone! |
Posted: Tue Feb 23, 2010 7:27 pm Post subject: |
Yes I do, I have a wonderful selection of surgical tools, angle grinders, hammers, stanly knives etc  |
redbimotal
Posted: Wed Feb 24, 2010 5:56 pm Post subject: |
O.k.,..........will ponder on what I will do next to attack this issue......
will take a while before I tackle this due to work but will surely keep you updated....Thanks Johny for your imput........appreciate it |
Admin Site Admin
Posted: Wed Feb 24, 2010 11:02 pm Post subject: |
Had a nightmare getting the front sprocket off my better halfs Triumph Thunderbird. Needed a 5 foot scaffold pole over a breaker bar to remove it. But that meant bracing the rear wheel, which was a spoked wheel and so wouldn't take bracing against the swinging arm.
Keith |
jonoft
Posted: Mon Mar 01, 2010 10:31 pm Post subject: |
SB6 came with 532 chain. Most companies like Talon (UK), Sprocket Specialists (USA) and Wieres (Germany) will offer 530 conversions.
Regards
Jon |
redbimotal
Posted: Tue Mar 02, 2010 1:23 pm Post subject: |
Anyone out there know how many links are needed on the SB 6 ??? |
Mako
Posted: Mon Apr 30, 2012 1:01 pm Post subject: |
ok, so can we summarize the tec specs of a standard transmission kit for an SB6) as I'm abouto to buy and I don't want to order a wrong set
front sproket n. teethes? a GSXR1100 one is ok?
rear sproket n. teethes? special specs?
Chain: 530?
thanks _________________ Honda CB450K1 - CB750K2 - CB500K1 - RC30 - Ducati 750SS - Bimota SB6 |
Mako
