Posted: Sat Nov 02, 2013 10:40 pm Post subject: Timing belts |
Ducati tells us to change out the timing belts every 2 years regardless of mileage. My bike was built on 07/07, and as far as I could determine the belts had never been done, until today. Bimota did a good job hiding one of the screws on the verticle belt cover butt I managed to sneak in and get it out, everything else was pretty easy. There are vids on YouTube that cover most of the tricks, and it actually runs after the job! _________________ Spike C.
1965 Triumph T100SC |
Posted: Sun Nov 03, 2013 9:32 am Post subject: |
Always a contentious point of discussion with Ducati Cam belts......dealers always say 2 dyears, regardless of the engine..until you get to know the mechanics etc....If a high stressed engine, 1098's etc, 4 valve twin cams...then yeh...2 years....but as you prove yourself....2 valve single cam engines...I push to 4 or 5 as long as mileage isnt too high inbetween, and the bike has been regularly run so as not to leave the cam belts in the same position.
Used to be an issue many years ago, but the belts now have reinforcing kevlar strands in them that stops the frequent snapping on older bikes..some people on here push over ten years on belts...and dont seem to have had an issue....
At least with the 2 valve single cam engines the belts are cheaper also... |
Corona
Posted: Wed Nov 06, 2013 10:09 pm Post subject: |
Tend to run mine to 4 years old, check them beginning, middle and end of season or at about 2000 miles ish. I've seen belts on machinery take massive abuse and neglect for years of service (they may run slower but at higher loading), check for cracks or any fraying, sprocket alignment and tensioner rollers. The rear cylinder is a bit of a pig to change on a DB4 though. Good vids, should have thought of that . |
bimota_rider
Posted: Thu Nov 07, 2013 3:18 pm Post subject: |
.......sounds kind of like the Vineyard owner telling you that a glass of wine every night is good for your health........
. _________________ '98 Bimota SB6R #000016 "Sweet 16"
Built 5/97
2014 Suzuki Hayabusa
2001 BMW R1100S
Posted: Thu Nov 07, 2013 6:34 pm Post subject: |
Well, I do believe the vineyard owner! _________________ Spike C.
Posted: Fri Nov 08, 2013 12:15 am Post subject: |
| 2bims wrote: |
I'm guilty as charged. My db4 has over 22000 k's on it and i don't know for sure when the belts were done. The bloke i bought it off said they were done but doesn't know when. One of those jobs i've been planning on doing. I did pop the covers off and had a look and they looked to be in good nick. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Fri Nov 08, 2013 6:38 pm Post subject: |
| Was also Guilty as Charged....DB4 had 28,000 Kms when I bought it...done a couple of K since and they were changed this year...belts were reckoned to be Originals with Non-kevlar reinforcement.....So not an issue apparently...Oops.... |
Posted: Fri Nov 08, 2013 7:36 pm Post subject: |
So your belts were only, what, 12 or 13 years old? With around 18000 miles on them? And no Kevlar? _________________ Spike C.
Posted: Fri Nov 08, 2013 9:41 pm Post subject: |
Ehhhhh....yup....13ish years old, as its a 2000 bike....kind of goes along with the Mine Merchant selling red wine.....gets better with age  |
Posted: Sat Nov 09, 2013 10:17 pm Post subject: |
| 2bims wrote: |
Yeah, lots of things get better with age! (my back is not one of them ) _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
