Weed
Posted: Tue Dec 31, 2013 11:09 am Post subject: Dash / Tacho Combo |
Has anyone had one of the original dashes apart? Neither the Tacho or speed are working. I have been told that it is common for a diode to come lose inside & I need to carry out some repairs. |
Posted: Tue Dec 31, 2013 9:54 pm Post subject: |
They are very prone to loosing 'segments' of the display.
Probably worth speaking to Piero, especially as you have lost both functions. |
SB8R Tuner
Posted: Tue Dec 31, 2013 10:17 pm Post subject: |
Is this for an injected or carbureted bike? If it's carbureted, I have two SB8K ecu's apart right now? |
Weed
Posted: Wed Jan 01, 2014 4:17 am Post subject: |
JRH wrote: |
I managed to get it apart & a capacitor was lying in the bottom of the dash. I will get a new one & fit it up to see if it solves the problems. Thanks for the Piero tip.
cheers |
Weed
Posted: Wed Jan 01, 2014 4:19 am Post subject: |
SB8R Tuner wrote: |
She is an injected girlie. Thanks for the offer. As above I will be working on it when the shops open in the New Year
Cheers |
Posted: Wed Jan 01, 2014 10:31 pm Post subject: |
Yep the blue diode falls off inside
Trev |
Weed
Posted: Thu Jan 02, 2014 9:26 am Post subject: |
trev45 wrote: |
Trev |
Thanks Trev. How is the No1 member of the 2 member Australian VDue club going. Did you have a good Christmas / New Year? |
Posted: Thu Jan 02, 2014 11:19 pm Post subject: |
But now there is a third member
a mate Pete took one of the carby
ones off me that I built , a all new bike too
He is in QLD
Trev
Weed
Posted: Fri Jan 03, 2014 5:21 am Post subject: |
Shit mate, at this rate we will be able to start a movement in the words of Arlo Guthrie
I fitted a new diode so the tacho is going round. Are the tachos very flighty for want of a better word or do I still have a problem? It does read RPM ok once the needle is put back on in the right spot but it does waver around a bit.
Cheers |
Posted: Fri Jan 03, 2014 12:08 pm Post subject: |
Its a 2-stroke, designed by Italians and an electronic dash....so if its wobbling around a bit youre fortunate that its working.... |
Weed
Posted: Fri Jan 03, 2014 10:07 pm Post subject: |
2bims wrote: |
Yes, I suppose the movement I have is better than the movement I had. |
Posted: Fri Jan 03, 2014 10:36 pm Post subject: |
They do move a little bit
But working good stuff
Trev |
Posted: Sat Jan 04, 2014 1:00 am Post subject: |
I have the later one piece led dash....temp is stuck at 40, low fuel light works, but thats only 70miles anyhow, Speedo at 40 varies between 25 and 70, up to a 100 it can read 190.....so, no idea if its cooking itself, or what the real speed is, but the tachos fine so can time gearchanges ok,,,grateful for small mercies... |
Posted: Sat Jan 04, 2014 1:06 am Post subject: |
Posted: Sat Jan 04, 2014 3:48 pm Post subject: |
I must be the lucky one, mine works perfect! It's a bugger to read in bright sunlight, but that's not a hassle in the UK!!! |
