mm500
Posted: Sat Mar 08, 2014 8:18 am Post subject: Delivery of my V Due from Italy |
Got my bike delivered from Piero yesterday
mm500
Posted: Sat Mar 08, 2014 8:20 am Post subject: |
I'am installing the original exhaust this weekend before I show it to the DMV on monday  |
Posted: Sat Mar 08, 2014 9:11 am Post subject: |
Excitement levels at 11
Stunning. Enjoy. _________________ Now - SB6R, GSX1400, KTM 990 SuperDuke
It was like that when I got here  |
Posted: Sat Mar 08, 2014 11:04 am Post subject: |
Very nice indeed...and with the added extra of the fuel tap on the left....take your time re-fitting the standard pipes....they need to be fitted to the seat unit off the bike then put them on the bike to the headers....And if your DMV is anything like the UK one you'll need to fot them....noise levels of the Jolly Motos are 105-110Db at half revs of full power...4500 revs...
With the standard pipes you should creep under the 100Db limit (or at least thats what it is in the UK at the test...) |
Posted: Sat Mar 08, 2014 12:38 pm Post subject: |
Very nice mm500. Did the crate have the bimota logo on the side? I'd so like to have an original bimota shipping crate... Especially if it had an original bimota inside  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
mm500
Posted: Sat Mar 08, 2014 12:45 pm Post subject: |
brian, yes it did.
2bims, as long as the original exhaust is fitted they don't check the Db  |
Posted: Sat Mar 08, 2014 1:05 pm Post subject: |
How would they know which is the original exhaust then? Cant imagine they will have seen many Bimota Vdues in Norway........
Our UK Standard yearly test does not test the Db levels...but may put advisories on the certificate to protect themselves if they appear "noisey"...Meanwhile the test for newly imported bikes does test the Db levels with the engine at half revs of full power.....Although for V-dues...as long as you can convince them that the bike is over 10 years old...such test is not needed...just a simple MOT.... |
mm500
Posted: Sat Mar 08, 2014 1:17 pm Post subject: |
E3 markings on the exhaust
Posted: Sun Mar 09, 2014 12:51 pm Post subject: |
Love it good to see one more for the road / track maybe
Trev |
mm500
Posted: Wed Mar 12, 2014 5:45 pm Post subject: |
everything went smooth at the dmv
changing tyres to Michelin Pilot power 3 and painting the wheels black
Posted: Wed Mar 12, 2014 6:12 pm Post subject: |
Looking good...and will be better with the shiney black wheels...and Jolly moto pipes...take it easy until you get used to it........and once you've mastered it.....sweet.....found anything that doesnt work as it should yet?
First gear can be tricky to get away...and if you stall it...it wont start in gear...even with the clutch pulled...you have to ensure its in neutral, and the neutral light is on (because you can get one or the other at times...but both are needed)...the rear sprocket hub assembly is normallt silver even with black wheels...may look good in black also though? |
mm500
Posted: Wed Mar 12, 2014 6:43 pm Post subject: |
everything works as it should
I had to use heat to get the front disc of the wheel, do to treadlock.
I need to figure out a solution with the front bellypan screws rubbing against the carbon airbox on bouth sides. |
Posted: Wed Mar 12, 2014 8:18 pm Post subject: |
| mm500 wrote: |
Thats a good sign on the front discs.....when I checked mine they were only finger tight........Oh eh......
Oh the belly pan screws....you may find several different lengths of screws holding all the bodywork in....but all the same diameter and thread.....on the belly pan the shorter length is sufficient...and should clear...or put protective sticky rubber pads on the areas where the screws meet........But oh my....arent you "prescious" with your new toy??
Thinking about it...and looking at the carbon air box...each of them has "dimples" 2 No...that must be there to accommodate the screws...so if yours are touching then change for shorter ones...simples |
mm500
Posted: Wed Mar 12, 2014 8:30 pm Post subject: |
I will do that, thanks for the tip  |
mm500
Posted: Wed Mar 12, 2014 8:34 pm Post subject: |
yes I'am very prescious with all my italian toys  |
