roy54
Posted: Fri Apr 04, 2014 11:38 pm Post subject: |
| Looking good Roy. All nice clean and fresh for a Summer of riding. |
roy54
Posted: Sat Apr 05, 2014 2:04 pm Post subject: |
thanks for the heads up on lights steve i think im more or less done with the bike for now would you know witch is the better unit and is one like the type on the v due also cheers to bud keep us up to date with what your doing mate went to oz seven yrs back family in brisbane and friends in mindari perth stunning country and met great people good breakfasts at hillarys. |
Posted: Sat Apr 05, 2014 3:47 pm Post subject: |
The one thats titled "Yamaha FZR400RR Sp 3TJ Headlight Head Light Lamp" is more light the Vdue lamp as the right lamp as you look at it is a Projector beam for High Beam...and the left lamp is main beam only...and usually a small sidelight bulb between them......NOS Vdue ones do come up from time to time....you just have to check if theres sufficient space at the back of the lamp with wiring boxes/connectors etc as they are a good bit deeper for the projector beam lamp unit.......I retro fitted a Vdue one on to my DB2 that had the same single lamp as per the YB11...and had to cut a slot in the unit to allow the speedo drive cable to fit...and move a few other things around locally.......tight squeeze but refreshed the front end nicely
This is what a Vdue headlight looks like...which again is slightly different although the body, brackets and fixing and size are the same
And this is a Db4 unit
And a Vdue unit...(any excuse to post up this lady again.......If you're after a Vdue unit pop a note to Vort...as I think hes ordering some more parts again and may be able to get hold of one for you
Posted: Sat Apr 05, 2014 9:13 pm Post subject: |
The FZR400 unit is from the 3TJ or 4DX its not necessarily the SP version but be aware they are rather crap as actual headlights and the bulbs are expensive. _________________ Don't read everything you believe |
Posted: Mon Apr 07, 2014 7:26 pm Post subject: |
| Problem with the vdue/db4 unit it the projector beam unit is quite deep and I think from memory it will not fit in the YB11 gap between the headlight unit and the clocks,if memory serves me correctly I only just managed to get the twin beam FZR unit in . Will have a look for you Roy at the w/e. |
