bimotacarbon
Posted: Sun Apr 27, 2014 5:49 pm Post subject: Which type of rear fender is this? |
Hi there,
In my search for the rear fender for a sb6r someone offered one too bad, not a6R type.
Does anyone have an idea wich bimota this one belongs to??
Kind regards johan
 _________________ Ducati 750 SS café racer, BMW R nine T Cafe Racer, Husqvarna Vitpilen, KTM Rc8, Husqvarna Vitpilen 701, Bimota DB6 |
atomibart
Posted: Sun Apr 27, 2014 6:35 pm Post subject: |
Hi,
Is it still for sale or did you buy it ?
Is is in good condition ? I might be interested but I nedd to check something before...
atomibart |
Posted: Sun Apr 27, 2014 11:49 pm Post subject: |
YB maybe?  _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Mon Apr 28, 2014 10:39 am Post subject: |
Johan
Not sure about that one, but if the SB6R uses the same rear swingarm as the SB8R, I have a used SB8R hugger hanging on my garage wall. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Mon Apr 28, 2014 11:23 am Post subject: |
I can confirm its NOT DB2/3/4 or Vdue.........Does look very similar to YB11 but the chain guard side is cut away too much...line on the right is correct...as is the cut out at the front/recess for a bike with a centrally/vertically mounted YB series......So I'd say its an earlier YB Hugger
I'd go for YB9....these have a diagonal section of Carbon fibre chainguard built into the hugger like this...with parallel sides...and evidently the central rear shock needing the recess in the hugger.... |
Posted: Mon Apr 28, 2014 12:58 pm Post subject: |
The 6R swingarm is a bit different to the 6 - it has more bracing on the shock side
So I'd say your hugger isn't from a SB6 ... it hasn't got the small cut out on the shock side ... YB11 would be my guess.
SB6 hugger - I was polishing it
Posted: Mon Apr 28, 2014 9:00 pm Post subject: |
looks like a carbon version of my yb7 with the two small mounting lugs. what is the distance across the hugger between the mounting holes? _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
atomibart
Posted: Tue Apr 29, 2014 3:57 pm Post subject: |
| I'd go for YB9 too... |
Posted: Tue Apr 29, 2014 8:57 pm Post subject: Rear Hugger |
Looks like it would fit a YB8. Might be interested, if Atomibart doesn't take it off you. _________________ What, Jonny's gone! |
roy54
Posted: Wed Apr 30, 2014 9:35 am Post subject: rear fender |
| for what its worth i would go with yb11 cheers roy |
Posted: Wed Apr 30, 2014 10:22 pm Post subject: |
It's not the same as a YB8 hugger, but I guess anything can be made to fit with enough work.
GerardVenema
Joined: 08 Feb 2014 Posts: 5 Location: Heemstede,the Netherlands
Posted: Sat May 10, 2014 10:20 am Post subject: |
| Looks like the rear hugger from my yb9 sr.... |
