Posted: Thu May 15, 2014 8:42 am Post subject: |
| sb8rs wrote: |
Hi,
If you have standard bearings in and do not use the taper it is a good idea to do this.
Do you have the FAG number for these bearings please. |
did you want the bearing number for the KB1 headstock bearing? I think they were about £25 each from memory. _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
ade critten
Posted: Thu May 15, 2014 9:08 am Post subject: |
| bimotanige wrote: |
| sb8rs wrote: |
Hi,
did you want the bearing number for the KB1 headstock bearing? I think they were about £25 each from memory. |
The FAG # for the YB8 bearings is 502365. |
sb8rs
Posted: Fri May 16, 2014 8:56 pm Post subject: |
bimotanige,
Sorry I worded it badly.
You said you put a standard taper bearing in, rather than the original 502365.
Can you advise on this replacement bearing number.
Thanks |
