polyesterpig
Posted: Wed Jun 18, 2014 6:28 am Post subject: YB8 triple clamp dimensions |
I need to know the triple clamp offset dimensions (should be 30mm or 35mm?) and the center to center distance of the fork tubes (190mm?). This is for the YB8 with the UP side down ohlins forks & 54mm diameter top tubes.
I also need to know the same triple clamp dimensions for the YB11 with 51mm paioli conventional forks. Any help appreciated! _________________ 2002 Cannondale E440
(3) 2003 Cannondale E440R
2000 Bimota DB4ie BiPosto |
Posted: Wed Jun 18, 2014 11:35 am Post subject: |
hi, sorry I can't help as mine is fitted with the early forks.
Hopefully someone else can help? _________________ Bimotas, Yamaha FZR 2TK, Honda NC30, MV Agusta F3 800, Aprilia RS250 |
Posted: Thu Jun 19, 2014 12:12 am Post subject: |
My YB8 with the early RWU forks has triple clamps with 190mm spacing and 35mm offset.
It's possible that Bimota kept the same set up when they went to USD forks. |
polyesterpig
Posted: Sat Jun 21, 2014 3:45 am Post subject: |
Thanks for the help! Still could use a few more measurements if possible. _________________ 2002 Cannondale E440
