Engine woe
PostPosted: Mon Jul 14, 2014 12:25 am    Post subject: Engine woe Reply with quote
Intake valve on vertical cylinder dropped its head, holed the piston. I found a used Multistrada 1100ds on ebay with the same miles on it as mine.
The manual says there are 3 bolts to remove after removing the swing arm axle, butt I only see 2! There must be an invisible casting up at the top frame attachment.......
Spike C.
1965 Triumph T100SC
PostPosted: Mon Jul 14, 2014 1:43 am    Post subject: Reply with quote
Sorry to hear that mate. Were the valves adjusted too tight?
