Sb6-R Speedo sensor needed!!
SB6-RSF
PostPosted: Wed Jul 23, 2014 9:06 pm    Post subject: Sb6-R Speedo sensor needed!! Reply with quote
Hi all! Is there anyone out there that could tell me where I can get hold of the speedo sensor for my bike? I guess it`s the same for the YB11 and the V-due. I need the part number if anyone have it as well. Thanks in advance! From hopefull norwegian with a big grin on his face from finally driving his SB6-R after 6 years of ownership...
HD: The best way to convert petrol into noise without the side effect of
horsepower...
PostPosted: Thu Jul 24, 2014 9:57 am    Post subject: SB6R speedo sensor Reply with quote
If it's non-functioning clocks that are leading you to look at replacing the sensor, you are likely to find that it is the clocks that are at fault. They are not a well made item and are best put in the bin Sad
SB6-RSF
PostPosted: Thu Jul 24, 2014 4:32 pm    Post subject: Reply with quote
The sensor is only partly there... Probably due to the excursion into the grainfield where it ended the motorcycle career for the previous owner. (He is OK BTW)
horsepower...
SB6-RSF
PostPosted: Thu Jul 24, 2014 4:43 pm    Post subject: Reply with quote
If the clocks are s***t, there must be easy to get hold of a sensor..? OSmile
I guess a lot of people have converted into other brands of clocks/instruments?
horsepower...
PostPosted: Fri Jul 25, 2014 9:29 am    Post subject: SB6R speedo sensor Reply with quote
I'll see if I've still got one. Are there still some bolts in the disc bobbins?
SB6-RSF
PostPosted: Fri Jul 25, 2014 10:28 am    Post subject: Reply with quote
Splendid! The 4 (I think it`s 4) bolts in the disc is still there! Will be very pleased if I could buy a working sensor from you! Very Happy
horsepower...
PostPosted: Fri Jul 25, 2014 7:56 pm    Post subject: SB6R speedo sensor Reply with quote
pm sent.
