atomibart
Posted: Tue Apr 07, 2015 9:39 am Post subject: Ultrasound cleaning |
Hello from France
I would need some feedback from members of this forum cause I want to clean injectors of one of my Bimotas by ultrasound bath as I did for the carburettors of my Supermono before. But I heard here and there that this could not be done for injectors which I doubt...
So I want to be sure by asking you guys
Thanks in advance for your technical advice
atomibart |
Posted: Tue Apr 07, 2015 11:27 am Post subject: |
It might be better to contact the injector manufacturer and ask what they recommend _________________ Don't read everything you believe |
Weed
Posted: Mon Jun 15, 2015 11:56 am Post subject: Re: Ultrasound cleaning |
| atomibart wrote: |
Hello from France
atomibart |
On a slightly different note, I bought an ultrasound bath a couple of years ago & not had any success in cleaning anything. Obviously operator error but I am using the correct chemicals for alloy in the bath, the temperature appears to be correct but is there a time limit to leave the items in the bath. I have only ended up with bad results. the bath is made by a reputable manufacturer in Australia but unfortunately they haven't been much help. if I weren't a couple of thousand miles away from them I would drop in and see them
Posted: Tue Jun 16, 2015 6:36 pm Post subject: |
Hi Weed, when you turn on your ultrasonic does the surface of the liquid "dance"? How long are you leaving the parts in? _________________ Spike C.
1965 Triumph T100SC |
Weed
Posted: Tue Jun 16, 2015 8:12 pm Post subject: |
| SpikeC wrote: |
| Hi Weed, when you turn on your ultrasonic does the surface of the liquid "dance"? How long are you leaving the parts in? |
Good morning Spike. I haven't used it of about 18 months but I don't recall the surface dancing, only me in frustration.
I generally left the parts in for 30 minutes & when it didn't work I gave it another 30. I was working on a similar theory to the one that if you are speaking to someone who doesn't speak english then just talk louder & they will understand.  |
Posted: Tue Jun 16, 2015 9:38 pm Post subject: |
| if the surface isn't moving then its likely the vibrating plate is fubbarred..... |
Posted: Tue Jun 16, 2015 10:05 pm Post subject: |
Yes, your sonic is toast. Or defective. Either way you need a new one.
Sorry about that! _________________ Spike C.
Weed
Posted: Wed Jun 17, 2015 1:38 am Post subject: |
| Thanks guys. I will reload it and test it again. What effect does fluid the temperature have? I had that turned up to the max as well. About 80 deg C |
Posted: Wed Jun 17, 2015 2:45 pm Post subject: |
The temp can soften oil and grease like using hot / cold water for washing up _________________ Don't read everything you believe |
rudadue
Posted: Wed Jun 17, 2015 6:01 pm Post subject: |
| An other way would using ultrasonic cleaner but suspending injector so you can supply voltage so injector in the open position to get full benefit of cleaning, a bit it like throttle valve gumming up cause of egr exhaust gases being re introduced to inlet charge just a thought guys regards bill |
Posted: Wed Jun 17, 2015 6:13 pm Post subject: |
| rudadue wrote: |
Run the engine and spray carb ... or injector cleaner into it. _________________ Don't read everything you believe |
Posted: Thu Jun 18, 2015 5:40 pm Post subject: |
My DB5R had sticky injectors when I got it, I ran a few tanks with Techron injector cleaner in the fuel and it cleared up very nicely.
Vrooom Vrooom!! _________________ Spike C.
