Got an itch
Goto page Previous  1, 2
PostPosted: Thu Aug 18, 2016 9:14 pm    Post subject: Reply with quote
Hi Gavin, been thinking about it .Thanks for the offer but think I will give it a miss .
Gavin944888
PostPosted: Sun Aug 21, 2016 11:39 am    Post subject: Reply with quote
Okay.....no issues all still good.
Further research dictates that ONLY the DB9 exhaust is a straight fit as the manifolds are different between the 1098 and the 1198 as are the bolt positioning on the exhaust head side.....aswell as the actual opening into the pipe.Therefore DB7 and 8 use a different exhaust manifold and apparently it can be altered but it it is not an easy job
Although the 1098r headers ARE the same ......like most things Ducati the r version was the next step up in engine development. ...so a new secondhand OEM 1098r with 5 Kmis is leaving Holland this week in order to be chopped and coerced into a different route.
Cagiva Elefant 999r engined
Cagiva BIMOTA Motard Concept
BIMOTA DB11 VLX Supercharger
PostPosted: Mon Aug 22, 2016 5:30 pm    Post subject: Reply with quote
My apologies Gavin, I've been away and didn't see your emails.
Gavin944888 wrote:
Gentlemen, if like me, you struggle with posting pictures on the Forum, I would like to thank Brian from Oz and in this case 2Bims.
....many thanks from a tech Luddite.
Gavin
Page 2 of 2
