Wiring diagram
mickgrim
PostPosted: Thu Sep 15, 2016 9:28 am    Post subject: Wiring diagram Reply with quote
SB8R ECU wiring diagram doe's anybody have a copy.
Lost the spark and gone through all the usual stuff now down to ECU output.
SB8R owner and loved most of it.
Now DB9 & bonded
3 bims Jota 180 zx6 track bike & a grom
mcspeed.1
PostPosted: Wed Feb 22, 2017 4:55 am    Post subject: Reply with quote
Just ordered the full service manual. It's a long shot, but I will let you know when I get it.
PostPosted: Wed Feb 22, 2017 9:39 am    Post subject: Reply with quote
Do either of you have the Original Bimota owners manual for the bike? Often the wiring diagram is in the back of this in a fold out section...and not contained in the Workshop manual...they chopped and changed between models...but its normally only in ONE of them...and not BOTH...You'll also have to learn to translate the colour scheme of the wiring diagram from Italian to English...as all the coloured abbreviations are in Italian...I translated these and posted them up on here, into English...I'll dig it out if you wish
mcspeed.1
PostPosted: Wed Mar 01, 2017 2:57 am    Post subject: Reply with quote
Just got the full service manual and it has nothing for the ECU circuits. It does have the wiring diagram but nothing circuit wise other than the TPS ohm readings. Previous owner of my bike gave up nothing but the bike when I bought it.
SB8R Tuner
PostPosted: Fri Mar 03, 2017 6:58 pm    Post subject: Reply with quote
If you have good power and ground along with a signal from the crank and camshaft sensor, the ecu is bad. I have repaired a couple of them for that same problem if you need to get it repaired.
Bimota SB8R
Bimota V-Due
Bimota SB8R
Suzuki 1988 GSXR-750
Suzuki 1989 GSXR-750R
mickgrim
PostPosted: Sat Jan 06, 2018 3:55 pm    Post subject: Reply with quote
Got the ECU back at last new chips fitted and now sparks and purges fuel pump should be back on the road this year.
Not used because of this fault for last 6 yrs.
Amused myself on my DB9 for 18 months and that needs sorting over the winter.
So thanks for the help .
Now DB9 & bonded
