BIMOTA Sticker(s) removal ??
daotoys1
PostPosted: Fri Mar 17, 2017 9:48 pm    Post subject: BIMOTA Sticker(s) removal ?? Reply with quote
Whats the best way to remove the information / warning stickers that come on the bike ???
Im wishing to remove them without damage or harm to the bike / finish
Any good methods to share ?
thanks
d.
PostPosted: Fri Mar 17, 2017 10:44 pm    Post subject: Reply with quote
Wifes hairdrier to start with...as it wont damage the paint but will soften the glue....after that Brake cleaner or WD40 will remove glue residue without damaging paint...cotton wool balls and rub like crazy...when it becomes ineffective....change cotton wool balls and add more WD40 or brake cleaner.....then T-cut and/or polish...You can use a heat gun also but evidently too close and too long and it can melt paint.....Acetone/nail varnish remover on cotton wool again can take glue off after stickers removed but can also take paint off if applied too harshly...always take your time...starting at a corner and prise up slowly...always applying heat...if it tears...try another corner etc etc
PostPosted: Sat Apr 01, 2017 3:17 pm    Post subject: Reply with quote
I use Prepsol. Or any similar solvent that a painter would use to clean the surface of oils and contaminants before painting. Works a treat amd won't damage the paint
