rpo83
Posted: Sat Dec 30, 2017 5:57 am Post subject: Brake Pad question for the old school Brembo F08 Calipers |
Hi All,
as most of the early flavours of Bimotas, shared the same or similar Brembo calipers, i was wondering if anyone could make some recommendations for brake pads?
I'm about to rebuild the calipers and fit new master cylinders and S/Steel brake lines, so it's time for new pads, what works, doesn't work, i'd rather choose a pad that will be kind to the discs if there is one.
Can anyone also tell me the part # for the YB5 rear caliper? The only reference i have found is 20.2742.30 but i can't find any reference to it, i may as well rebuild the rear whilst i'm at it.. The fronts are Goldline F08's, but the rear is black and a different model...
_________________ Cheers
Steve
Posted: Sat Dec 30, 2017 12:19 pm Post subject: |
FO8's or PO8's????....These guys sell brembo spares....youre right...IMHO..to go for softer pads to preserve discs...pads are cheaper and easily available compared to the discs...as you have high iron content discs front and rear...steer clear of red plate backed brembo pads...these are sintered race pads and will eat your discs alive....I always try to get brembo original....
https://www.mdinaitalia.co.uk/search/for/brembo/page/1/
These guys I've also used...selling PO8 rebuild kits....bolts and seals...to give you an idea of price....
http://www.ducati-kaemna.de/catalogsearch/result/index/?p=2&q=brembo |
Posted: Sat Dec 30, 2017 9:49 pm Post subject: |
I get my Brembo pads locally from Gowanlochs. He knows which pads are for which disc material so that helps. |
rpo83
Posted: Sat Dec 30, 2017 11:11 pm Post subject: |
Hi Steve,
i got these codes from this web site http://www.thisoldtractor.com/brembo_brembo_brake_and_clutch_cross_reference_for_bimota_motorcycles.html
From searching those #'s i found a cross reference to F08, but rumaging around some Ducati pages i saw P08's mentioned for Ducati... If you have any further light you can shed on the subject it would be appreciated.. I believe the F08 and P08 share the same piston diameter, other than that i don't know the difference between them
Any idea on the rear caliper?? _________________ Cheers
Steve
rpo83
Posted: Sat Dec 30, 2017 11:13 pm Post subject: |
Hi Lech,
which Gowanlochs??? The store that uses his name, or the man himself?? _________________ Cheers
Steve
v-pilot
Posted: Mon Jan 01, 2018 6:56 am Post subject: |
The older Italian stuff I've had used the F05 caliper on the rear. I had good results from the Ferodo's _________________ 02 aprilia RSVR Mille, 02 aprilia SL1000 Falco
96 Ducati 900 SS/SP
78 Moto Guzzi V50
68 benelli 250 65 Ducati 250 |
PaulDB2
Posted: Mon Jan 01, 2018 11:25 am Post subject: |
I believe the rear caliper is a Brembo P32 variant, same as fitted to the DB1. Rebuild kits should be easily available. Lovely looking YB5 _________________ Bimota DB1, Bimota YB5, Bimota YB6 Exup, Bimota YB9 SR, Ducati NCR Replica, Moto Guzzi 750 S3, Honda CR750 race replica, Seeley-Suzuki TR500 |
rpo83
Posted: Mon Jan 01, 2018 12:51 pm Post subject: |
Thanks Guys,
Paul, i think you are correct... Thanks. _________________ Cheers
Steve
