Posted: Sun Apr 22, 2018 2:38 pm Post subject: |
Who do they employ to fix tjem???... A radid rottweiler????.... Ooo the tension.....switch the hox on...switch the box on....do they work????...tune in next week to find out.... |
Joined: 29 May 2009 Posts: 1744 Location: West Yorkshire
Posted: Sun Apr 22, 2018 5:01 pm Post subject: |
you been hitting the sherry bottle again matey?  _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Sun Apr 22, 2018 5:30 pm Post subject: |
used phone to reply....no glasses...and no deidre barlow around to borrow from |
Posted: Mon Apr 23, 2018 9:32 am Post subject: |
2bims wrote: |
No glasses .... you drink sherry from the bottle ???
That's hardcore _________________ Don't read everything you believe |
Posted: Mon Apr 23, 2018 11:28 am Post subject: |
Evilchicken0 wrote: |
2bims wrote: |
That's hardcore |
Very close to the truth that one.....Last year "CNC" from the Forum stopped over for a few days before and after being en route to the Classic TT.....and as a thankyou he gave me a bottle of "Kmetija Stekar 1672 Givi Pinot".....I said thanks...but had no idea of what it was other than reading "pinot" which matched with the colourless clear solution inside a 500Ml bottle marked 4%...seemed rude to ask what it was...hes from Serbia/Croatia/Slovenia...I forget which....Anyhow...I had a friend stay over again last week, told him the story, so after a curry night out we returned and cracked it open and took a few slugs from the bottle to decide....Hhmmm...Glasses....the 4% is actually 40 % Volume...and yup...pure vodka...glug glug..... |
Posted: Mon Apr 23, 2018 2:04 pm Post subject: |
2bims wrote: |
Ahhhh 1672 Givi Pinot .... as the slogan goes "Fit the hangover" _________________ Don't read everything you believe |
Posted: Mon Apr 30, 2018 9:23 pm Post subject: |
so - in preparation to re-fitting the clocks, I decided to give them a spruce-up. I had noticed that the speedo and tacho plastic lenses looked tired - discoloured and pitted - and having carefully dragged my thumb nail across them, I now know why.................
question is - were they lacquered during manufacture, or sometime later? _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Tue May 01, 2018 7:34 am Post subject: |
Perhaps someone was trying to "waterproof" them??/
Find a discreet area, on the clocks that is, and some Nail Varnish Remover/Acetone, apply with cotton wool...All items readily available FOC from a ladys boudoir.....  |
Posted: Tue May 01, 2018 1:19 pm Post subject: |
2bims wrote: |
No - if these have plastic rather than glass then acetate will make it go milky. _________________ Don't read everything you believe |
Posted: Tue May 01, 2018 1:40 pm Post subject: |
it (the lacquer) has been removed carefully by thumb nail. What is it that polishes plastic to like new, as used on bike fairing screens - Solvol? toothpaste?
Anyone? _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Admin Site Admin
Joined: 22 Oct 2007 Posts: 504 Location: Stafford, UK
Posted: Tue May 01, 2018 1:45 pm Post subject: |
I know toothpaste is used by some model builders to polish up aircraft canopies and the like. It is a very mild abrasive.
But also possible to use one of the kits designed for polishing up scratched headlights.
Katy |
Posted: Tue May 01, 2018 5:35 pm Post subject: |
THere are Plastic polishes like Mothers.......I've used toothpaste on the rear light unit of the KDX220...but I had to use a cotton polishing sizel mop on a power drill also...it did polish it up, and remove scratches...."jewellers polish" is another.....but again check if OK for plastic.....I have used T-cut in the paste also to effect on plastic clear headlights...... |
Posted: Tue May 01, 2018 6:18 pm Post subject: |
should I use "whitening" or "sensitive" tooth paste? _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Tue May 01, 2018 8:33 pm Post subject: |
Use the Tube you stole from my Bathroom window cill the last time you stayed over.....at least theres no cost involved then eh???........  |
Posted: Tue May 01, 2018 8:42 pm Post subject: |
