Clocks Away !
Goto page Previous  1, 2, 3
PostPosted: Wed May 02, 2018 10:15 am    Post subject: Reply with quote
so - the speedo has cavity protection and the tacho has a brighter smile.
And the whole clock set looks much better for having had a shower in Mr Sheen.
Suppose I should refit them to the bike now...............
PostPosted: Wed May 02, 2018 11:32 am    Post subject: Reply with quote
Is that the last of my toothpaste all gone now then??
PostPosted: Wed May 02, 2018 1:21 pm    Post subject: Reply with quote
No - still in my "overnight" travel bag. I may yet return it................ Wink
PostPosted: Wed May 02, 2018 1:38 pm    Post subject: Reply with quote
this product...........
https://www.amazon.co.uk/QA1-Motorcycle-Furniture-certificate-Scratches/dp/B00CU6UTNA/ref=sr_1_2?ie=UTF8&qid=1525264716&sr=8-2&keywords=xerapol+scratch+remover
has been recommended to me by a top Suzuki GT750 restorer - he uses it for clock face restoration as well as on indicator and rear light lenses.
It's £20 on egay, but only £6.99 on Amazon. Field test results (on an old Suzuki TS speedo clock face) to follow.
PostPosted: Sun May 13, 2018 8:57 pm    Post subject: Reply with quote
putting the clock(s) back..............
the 3rd of 3 clock set mounting studs is behind these electrical connectors...
here (the stud with the shiny new nut attached)...........
Bimota have a habit of fitting self-locking / Nyloc nuts to studs that are secured in plastic components - I always replace them with a plain nut / lock washer / plain washer combo. But not on this one, as it's a swine to get to.
anyway, with the electrical connectors all re-connected, time to switch on the ignition and..............
the speedo dropped from 40km/h to zero, so all looks good with the repair.
Time to re-assemble the front end then...
and finally fit the fairing.........
road test next (when the replacement rear lamp assembly arrives).
PostPosted: Mon May 14, 2018 7:25 am    Post subject: Reply with quote
Have you bought yourself a blingey "carbon effect" Aerox QR50 rear light assembly or a "lexus" one?
PostPosted: Mon May 14, 2018 1:13 pm    Post subject: Reply with quote
a plain red one
and a "Lexus" one.............. Very Happy
PostPosted: Mon May 14, 2018 8:15 pm    Post subject: Reply with quote
With or without integrated indicators???
PostPosted: Mon May 14, 2018 9:18 pm    Post subject: Reply with quote
without - the ones with are illegal.
PostPosted: Thu Jun 07, 2018 11:42 pm    Post subject: Reply with quote
took the bike to the MOT test station today - it failed on a sticking front brake switch (was working OK before I left my garage) and a headlamp that dipped to the wrong side. I have purchased a beam deflector to sort the headlamp - the sticking front brake switch necessitated the removal of the front brake lever to access the tiny plastic plunger that operates the micro switch. I cleaned and greased the brake lever housing, refitted the plunger, lever and switch and it is working fine now.
Good news is that the newly-repaired speedometer worked a treat, as did the new rear brake light switch I fitted earlier this week.
PostPosted: Thu Jun 07, 2018 11:49 pm    Post subject: Reply with quote
Failed???...you really need a new MOT garage to go to Geekay......and throwing money away on a headlight deflector??/ Call yourself a Yorkshireman...whats wrong with PVC insulation tape???
Page 3 of 3
