Temperature gauge not working properly
PostPosted: Thu Nov 08, 2018 6:03 am    Post subject: Temperature gauge not working properly Reply with quote
Had a nice ride last Sunday on the Dieci. Noticed that my temp gauge was not working properly. The needle was just at the lowest hash mark (not resting on the pin) but it did not go anywhere above that. During the ride, especially in the slower sections of it I could feel plenty of heat coming out of the fairings at which time the needle moved up to mid way through the entire sweep but fell back to its position at the lower line once I got moving.
Would it be safe to presume faulty sending unit?
1991 Bimota YB10
2001 Yamaha R6
2007 Aprilia Bol dOr
PostPosted: Thu Nov 08, 2018 11:00 am    Post subject: Temp gauge Reply with quote
Hi Tirefriar
I've had the same trouble in the past on a YB8 and a clean up of the connector at the rad sorted it out. The sender was fine.
PostPosted: Sat Nov 10, 2018 7:34 am    Post subject: Reply with quote
Thanks Jonny. I have dielectric grease, will give it a go tomorrow. Cheers
1991 Bimota YB10
2001 Yamaha R6
PostPosted: Mon Nov 12, 2018 8:33 am    Post subject: Reply with quote
Jonny, looks like the problem solved. Thanks for the heads up.
1991 Bimota YB10
2001 Yamaha R6
PostPosted: Mon Nov 12, 2018 10:19 am    Post subject: Temp gauge Reply with quote
You're very welcome Tirefriar Very Happy
