Newbie from Spain.
Carlampio
PostPosted: Wed Nov 28, 2018 6:17 pm    Post subject: Newbie from Spain. Reply with quote
A 2007 DB6 Delirio is finally in my garage.
The bike has 25.000 km and some minor works to do.
Rear fairing
Transmision kit.
Fluid and oil change.
Belts
I rode it last Saturday to test, and my smile still continues. What a great bike!! Light, great on the brakes and very stable.
Good advice will be appreciated!
P.D. Do you now some way to make the clutch softer?
PostPosted: Wed Nov 28, 2018 7:31 pm    Post subject: Reply with quote
Welcome to the club and congratulations......the DB6 is a lovely bike to ride.....
What do you mean "making the clutch softer" Do you mean easier to pull the lever? If so....then firstly change the clutch fluid for new.....then...if necessary.....change the clutch slave for a maintenance free, guaranteed for life Oberon Clutch slave unit...or.....change the clutch handlebar mounted master for a Brembo radial unit or Accossatto unit......and get a matching one for the front brakes at the same time...……
What rear fairing does it need?
Carlampio
PostPosted: Thu Nov 29, 2018 6:25 pm    Post subject: Reply with quote
Sorry for my bad english!! Embarassed
Yes, I mean easier to pull the lever!
I will change the fluid, and see.
I didn't know the Oberon Clutch, maybe is because I was younger with my previous Ducati's, hahahaha
Thanks for the advice, It's very interesting.
As you can see the rear light is damaged, and I want to replace it.
I have heard about Benelli Tornado Tre light, and I have bought one. But It didn't arrive yet.
Thanks for your help!! Very Happy
PostPosted: Fri Nov 30, 2018 9:21 am    Post subject: Reply with quote
Did you buy a Benelli standard light or the LED version ??
If the LED, they are similar but mount slightly different so you need to do a little work to attach.
Welcome to the forum Very Happy
Carlampio
PostPosted: Fri Nov 30, 2018 11:43 am    Post subject: Reply with quote
I bought the standard one. I prefer to keep the bike "original".
Will be easier to fit?
Thanks for your welcome and help Very Happy
lobomau
PostPosted: Sun Dec 02, 2018 3:28 pm    Post subject: Reply with quote
welcome Carlampio,
I m also new with Bimota, DB6 1100 of 2007 bought in Spain with 4700km.
I m in Porto, North of Portugl.
Replaced the rear fairing light with one from Keeway 125 (LED).
needed very small adjustment onbthe carbon fairing, and a new fixing.
If you need, can sen pictures of that.
Have nice rides.
Maybe we will meet sometime.
Carlampio
PostPosted: Mon Dec 03, 2018 11:31 am    Post subject: Reply with quote
Bom día!
Nice to know about you!
Same year as my bike. I'm interested in the fairing light pictures!
Any info about the bike will be appreciated.
I will be very glad to meet you, I visited Porto with my KTM 1290 two years ago.
lobomau wrote:
welcome Carlampio,
Have nice rides.
lobomau
PostPosted: Mon Dec 03, 2018 11:42 pm    Post subject: Reply with quote
pictures
https://www.dropbox.com/s/s3aeonn3vgkfrpi/IMG_20181203_221807.jpg?dl=0
https://www.dropbox.com/s/0aqgp0timzx9nns/IMG_20181203_221733.jpg?dl=0
https://www.dropbox.com/s/1zi93jxb2kwvr7u/IMG_20181203_221839.jpg?dl=0
https://www.dropbox.com/s/q5vu5a3i6rhewey/IMG_20181203_222000.jpg?dl=0
https://www.dropbox.com/s/t4s8qwuzvdhjho4/IMG_20181203_221947.jpg?dl=0
Carlampio
PostPosted: Tue Dec 04, 2018 1:30 pm    Post subject: Reply with quote
Thanks for the pictures!!
Nice Montesa 348!! It was only for real men!
lobomau wrote:
pictures
PostPosted: Wed Dec 05, 2018 4:10 pm    Post subject: Reply with quote
My dad has a white one - I'm told I should pick it up and keep it
Carlampio
PostPosted: Wed Dec 05, 2018 5:57 pm    Post subject: Reply with quote
Sure, but be careful with your feet starting the engine!
quikduk
PostPosted: Fri Dec 14, 2018 10:16 pm    Post subject: Reply with quote
Welcome to the club. I too have a DB6...but am a bit far away to meet as I am in the states.
Re: the clutch, Ducati has used 22mm-25mm since 2001 or so. A larger slave cylinder piston helps the reduce the lever effort (insert bad jokes here...).
I have heard that 29mm works best but it depends on the brand...and there are several. Can't go wrong with the following:
- Oberon 29mm
- EVR 28.5mm
- STM 28mm
I second 2bims' suggestion re: replacing the master cylinders with Accossato parts. Pure moto-jewelry.
http://www.accossato.com/EN/motorcycles-accessories/racing-line.php
Yum yum!
Razz
arsenic
PostPosted: Sat Dec 15, 2018 7:05 am    Post subject: Reply with quote
- Oberon 29mm
- EVR 28.5mm
- STM 28mm
Yum yum!
Razz
Why not a PR19 from Brembo ?
DB8SP / Brutale 1090RR / 530EXC supermoto
Carlampio
PostPosted: Mon Dec 17, 2018 1:47 pm    Post subject: Reply with quote
Oh no!!
More ideas to improve my lever effort, hahahaha
Very interesting, thanks for the info.
- Oberon 29mm
- EVR 28.5mm
- STM 28mm
Yum yum!
Razz
PostPosted: Mon Dec 17, 2018 4:40 pm    Post subject: Reply with quote
Heres my last suggestion that will help...and its a lot cheaper than all the others
https://www.ebay.co.uk/itm/10-40kg-Hand-Strength-Power-Grip-Adjustable-Wrist-Forearm-Exercise-Hands-Pro-New/362467251318?hash=item5464bb5476:g:LoQAAOSw9z1bzzAm:rk:2:pf:0
