Sb6r fuel tank liner info please
Goto page Previous  1, 2
250GTLusso
PostPosted: Thu Mar 28, 2019 11:53 pm    Post subject: Reply with quote
Note to Brian - for cleaning metal tanks, don't use nuts/chains/etc inside the tank. Use a product called METAL RESCUE (Available at Home Depot in the US for $25 a gallon - you only need a gallon, although I had so many tanks to do I bought 5 gallons). Put it in the tank, and let it sit for 2 to 24 hours (depending on the level of rust) and drain (its resuable, so I also filter out the rust before I store it in a closed container for the next tank cleaning). Then rinse the tank multiple times with a small quantity of petrol (4 oz) to get all the residual METAL RESCUE out of the tank. I keep rinsing until I do not get any more METAL RESCUE out with the 4oz of petrol (it will not mix with petrol, as its heavier, so it separates out like water. I have used it in numerous steel tanks, and they turn out like new (literally) inside. Amazing stuff.
1978 Bimota SB2 00046
1978 Bimota SB2 W20089
1982 Bimota KB2 Laser TT 00090
1983 Bimota KB2 Laser S 00138
PostPosted: Fri Mar 29, 2019 12:01 am    Post subject: Reply with quote
Thanks for the info mate. I’ll do some research and see if it’s available in Australia, or if there’s an alternative. Cheers
Gammaboy
PostPosted: Fri Mar 29, 2019 12:47 am    Post subject: Reply with quote
For steel tanks it's hard to go past phosphoric acid for cleaning/treating rust - it leaves a nice layer of iron phosphate on the steel which helps prevent further corrosion.
PostPosted: Fri Mar 29, 2019 1:17 am    Post subject: Reply with quote
Thanks Ben. Options are good.
250GTLusso
PostPosted: Fri Mar 29, 2019 11:17 pm    Post subject: Reply with quote
Gents, the beauty of METAL RESCUE is that is NOT an Acid. And therefore does NOT attack the base metal of the tank. Try it. You will be amazed.
Page 2 of 2
