DB3/4 front end vibration under braking
ssz Mantra
PostPosted: Wed May 22, 2019 10:17 pm    Post subject: DB3/4 front end vibration under braking Reply with quote
Hi,
A fellow Mantra rider and I have experienced vibration on the front end of the bike, as if the wheel was jumpin through bumps when under braking. This gets especially bad if the bike is in a slight lean angle.
Has anyone experienced something similar and, more importantly, managed to fix it?
My bike is currently being looked at by a mech but helpful pointers would be much appreciated.
PostPosted: Wed May 22, 2019 10:50 pm    Post subject: Re: DB3/4 front end vibration under braking Reply with quote
ssz Mantra wrote:
Hi,
Things to check...
Brake rotors for runout (warp)
Wheels bearings
Steering head bearings
Wheel balance
Loose bolts or axle
quikduk
PostPosted: Thu May 23, 2019 12:47 am    Post subject: Reply with quote
Ditto and...
warped, bent or out-of-round wheel
I had the above happen and the balance didn't indicate it was out of spec...but hands off the bars check sure did. Talk about a wake-up call! Shocked
pkay
PostPosted: Thu May 23, 2019 4:15 am    Post subject: Reply with quote
My BMW R1100 had this problem - I thought it was the disk but turned out to be the hoses. Felt like a warped disk but it was the hydraulic pressure oscillating due to the degradation of the rubber hose. I fitted braided hoses and problem gone with same disks.
If your head bearings are shot you'll notice it when your riding - you should get a wobble through the steering that again feels like a warped rim or risk.
pkay
PostPosted: Thu May 23, 2019 5:34 am    Post subject: Reply with quote
I dont have much to add to that.....sometimes the steering head bearings need some grease and/or tightening up a little....Italians are famed for using tiny amounts of grease on such things.....When was the front suspension last refreshed? New fluids/seals...are they balanced in compression/rebound/preload.....Is the tyre still round and evenly worn? What the other boys state can cause uneven wear on the tyre....Are the caliper pistons moving in and out OK...or is the odd one sticking on one side causing uneven braking?
