Fuel level sensor SB6 leak
firefli
PostPosted: Mon Dec 16, 2019 5:27 pm    Post subject: Fuel level sensor SB6 leak Reply with quote
Hello.
I have a problem with the fuel level sensor, it has a leak. Leaking through the wire. I tried to glue the sealant but after a while it starts to flow again. Who solved this problem? What makes it possible to replace the sensor?
thanks
gunslinger
PostPosted: Mon Dec 16, 2019 8:47 pm    Post subject: Reply with quote
i managed to buy a brand new one on ebay 3 yrs ago. ill try to find the hint i got here for you. stand by..
SB6 mk1. YZF750R.FZR1000
gunslinger
PostPosted: Mon Dec 16, 2019 9:03 pm    Post subject: Reply with quote
unfortunately the ebay link does not work anymore. so cant give you the provider name...
search for "fuel-low". there you can find the thread.
good luck.
PostPosted: Thu Dec 19, 2019 10:05 am    Post subject: Reply with quote
Blank it off and use the trip odometer
PostPosted: Thu Dec 19, 2019 1:36 pm    Post subject: Reply with quote
+1 as above
PostPosted: Thu Dec 19, 2019 1:45 pm    Post subject: Reply with quote
I had the same with mine on my DB2.....I drained the tank and let it all dry...and used 2-pack epoxy to seal around the area...still all good after 2 years.....Any form of sealant would have to be fuel resistant to work...most aren't....
PostPosted: Fri Dec 27, 2019 12:52 am    Post subject: Reply with quote
To be honest I’m very surprised that the low fuel sensor is still working. Most of them pack it in. I’ve not yet seen a suitable replacement item. If it’s still working, seal it up with a 2 pack epoxy as 2bims said
