SB6 side stand.
PostPosted: Sun May 17, 2020 9:44 pm    Post subject: SB6 side stand. Reply with quote
New - never fitted.
£60 + shipping.
PostPosted: Fri May 22, 2020 6:30 am    Post subject: Reply with quote
Would this fit a YB10? Mine is pealing... Thanks
1991 Bimota YB10
2001 MV F4
2015 KTM RC390
atomibart
PostPosted: Fri May 22, 2020 8:47 am    Post subject: Reply with quote
Hi Geekay,
What is its length please ?
atomibart
PostPosted: Fri May 22, 2020 10:00 am    Post subject: SB6 side stand Reply with quote
Tirefriar, if your 10 has the suicide stand, this would not be a direct replacement. However, it could be used to convert to a non-suicide stand.
PostPosted: Fri May 22, 2020 10:06 am    Post subject: Sb6 side stand Reply with quote
If you’ve already got a non-suicide stand, this would fit but, as Atomibart says, you’d want to compare its length with what you’ve already got. You could always get your original re-chromed.
PostPosted: Sat May 23, 2020 4:49 am    Post subject: Reply with quote
Thanks Jonny. Problem is that I live in Kommiefornia where most chrome plating businesses were regulated out of existence. The Dieci has a suicide stand, would love to get rid of that feature. Wink
1991 Bimota YB10
2001 MV F4
2015 KTM RC390
PostPosted: Sat May 23, 2020 8:48 am    Post subject: Sb6 side stand Reply with quote
Tirefriar, you can convert to a non-suicide stand and I’ve just done it on my 8 - why I waited this long I’ll never know! First step is to source a stand like this - I can talk you through the rest - have you got access to an angle grinder for making a small bespoke bracket?
PostPosted: Sat May 23, 2020 9:55 am    Post subject: Reply with quote
Simple enough to do mate. You just need to figure out how to get the stand to ‘over-centre’ so that the spring tension holds it in the down position. Usually just a matter of moving the top fixing point of the spring. I’m not familiar with the YB’s
PostPosted: Sat May 23, 2020 9:10 pm    Post subject: Reply with quote
atomibart wrote:
Hi Geekay,
atomibart
Hi atomibart
it is 250 mm from pivot bolt centre to stand foot.
kind regards,
Garry.
PostPosted: Tue May 26, 2020 4:58 am    Post subject: Reply with quote
Thanks for the info. Will look it up.
1991 Bimota YB10
2001 MV F4
2015 KTM RC390
PostPosted: Tue May 26, 2020 6:00 am    Post subject: Reply with quote
The YB will be a little different as the spring is on the inside of the stand from memory, but this might help to visualise it....
In self retracting configuration, the spring is pulling the stand back up as it is secured to the right of the pivot..
After the modification, the top of the spring is secured to the left of the pivot, so it now ‘over-centres’ and holds the stand in the down position
